BUG in 2022? ApplicationEvents oAppEvents_OnReady doesnt fire
Frederik_Mussler
Message 1 of 12
Frederik_Mussler
Hey guys,
i just upgraded from Inventor 2019 to Inventor 2022. I just noticed that in my addin an InventorEvent is not fired anymore. Does anyone have the same issue. Simple Expample when i start Inventor i expect the "Ready" Messagebox to show up, but nothing happens. If i close Inventor, the MessageBox "Close" appears. So is there a bug in the new version or what is wrong?
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
' Inventor application object.
Private m_inventorApplication As Inventor.Application
Private WithEvents oAppEvents As ApplicationEvents
Private Sub oAppEvents_OnReady(BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles oAppEvents.OnReady
            MsgBox("READY")
End Sub
Private Sub oAppEvents_OnQuit(BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles oAppEvents.OnQuit
            MsgBox("QUIT")
End Sub
Replies (11)
Message 2 of 12
Ralf_Krieg
Hello
Can't test with Inventor 2022 right now, but just for the sake of clarity, your Addin is sure loaded at  Inventor start? What type of load behaviour is in your .addin file?
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 12
bradeneuropeArthur
Where is your oappevent declared?
Like :
Oappevent =inv.applicationevents
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 12
bradeneuropeArthur
Private m_inventorApplication As Inventor.Application Private WithEvents oAppEvents As ApplicationEvents
oAppEvents =m_inventorApplication.ApplicationEvents
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
Ralf_Krieg
Hello
Tested it now with 2022 and the event is fired.
R. Krieg
RKW Solutions
Message 6 of 12
bradeneuropeArthur
Please upload the complete code to see where the declarations are.
I am missing things!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
Frederik_Mussler
Sry, my posted code was not complete. Since i'm talking about a plugin that worked perfectly in 2019, i have not changed a line of code. So just for testing i startet a new blank addin with the SDK Template for Visual Studio.
Namespace InventorAddIn1
    <ProgIdAttribute("InventorAddIn1.StandardAddInServer"), _
    GuidAttribute("79167e06-f668-480d-8f20-ddb230a4da37")> _
        Private WithEvents m_InEv As ApplicationEvents
        Private WithEvents m_uiEvents As UserInterfaceEvents
        'Private WithEvents m_sampleButton As ButtonDefinition
#Region "ApplicationAddInServer Members"
        ' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
        ' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
        ' the first time. However, with the introduction of the ribbon this argument is always true.
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' Initialize AddIn members.
            g_inventorApplication = addInSiteObject.Application
            ' Connect to the user-interface events to handle a ribbon reset.
            m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
            m_InEv = g_inventorApplication.ApplicationEvents
            ' Add to the user interface, if it's the first time.
            If firstTime Then
                AddToUserInterface()
            End If
        End Sub
        Private Sub m_InEv_OnReady(BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_InEv.OnReady
            MsgBox("INVENTOR READY EVENT")
        End Sub
        Private Sub m_InEv_OnQuit(BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_InEv.OnQuit
            MsgBox("INVENTOR QUIT EVENT")
        End Sub
Quit Event Works, Ready not.
Message 8 of 12
bradeneuropeArthur
Are there other addins that use the ApplicationEvents?
What happens if you unload all Add-ins also from starting automatic.
and start Inventor new with only your add in loaded.
does it work than?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Frederik_Mussler
good idea, i started inventor with all addins unloaded except my addin, and so the Event was fired. So yes indeed it works than.
So enabling back the build in addins from inventor i just came across the Autodesk.Feedback.Inventor.addin
If i disable this addin everything works fine, if the feedback addin is enabled, i have the problem again with the event not getting fired.
Inventor Product Feedback Add In | Search | Autodesk Knowledge Network
So due to it is not an important addin, i can just let it disabled, maybe others can reproduce this behaviour and we can add this as a bug?
Message 10 of 12
bradeneuropeArthur
So partly solved!
@johnsonshiue
Could you please take a look at this with the development team?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
Frederik_Mussler
Yes thank you 🙂
Message 12 of 12
m.buehler1
Some news:
The issue of not working event ApplicationEvents.OnReady due loaded Feedback Add-On appears again in Inventor 2025 (2025.2 of October 2024)
I opened a support ticket - Confirmed, it is a bug (related to outdated NLog version 4.0). Autodesk will fix in future version.
