box data automatic with ilogic
benigno.martinezvaldez
I have an addin that create a Qr code .
this is the Addin
i want to write the part number in the box but automatic without write manually
This is my Rule that call the addin
Sub Main()
Sub Run_QR()
    Dim oDefs As ControlDefinitions
     oDefs = ThisApplication.CommandManager.ControlDefinitions
    Dim oDef As ControlDefinition
     oDef = oDefs.Item("CADStudio:XTools:CreateQRCode2")
    oDef.Execute
End Sub
Michael.Navara
What next? Do you want to show this QR code somewhere on drawing?
For this reason is there (in the XTools addin) automatic property conversion. QR code is stored as text in user defined property. Later on you can create sketched symbol or Titleblock, which can display this converted property value.
If you need more info, you can see the documentation and samples installed with the addin.
bradeneuropeArthur
Where is the code for the Dialogbox?
We need to have it for filling the partnumber in.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
matt_jlt
Only ways i can think of
Refer to samples / product support for the addin you installed
Use the Win API to get the window / hwind ID and access the form that way (I dont recommend this as its not always reliable and is complicated)
Create your own addin; utilising something like ZXing / open source tool as the basis and integrate it into your own form.
