boolean with text
boolean with text
martinhoos
Message 1 of 11
boolean with text
martinhoos
i dont understand that following code is not running...
boolean1 = True
boolean2 = False
If Typ = "left" Then
Typ_1 = boolean1
ElseIf Typ Then
Typ_1 = boolean2
End If
If Typ = "right" Then
Typ_2 = boolean1
ElseIf Typ Then
Typ_2 = boolean2
End If
If Typ = "middle" Then
Typ_3 = boolean1
ElseIf Typ Then
Typ_3 = boolean2
End If
If i Change the code from text to number (1, 2, 3) it will run. What is wrong?
Thanks in advance.
Regards
Martin
Replies (10)
Message 2 of 11
bradeneuropeArthur
Change to this:
Dim boolean1 As Boolean
Dim boolean2 As Boolean
boolean1 = True
boolean2 = False
If Parameter.Param("Typ").Value = "left" Then
	msgbox ("d")
End If
	iProperties.Value("Custom", "Typ_1") =  boolean1
Else
iProperties.Value("Custom", "Typ_1") =  Boolean2
End If
If Parameter.Param("Typ").Value = "right" Then
	iProperties.Value("Custom", "Typ_2") =  boolean1
Else
iProperties.Value("Custom", "Typ_2") = Boolean2
End If
If Parameter.Param("Typ").Value = "middle" Then
	iProperties.Value("Custom", "Typ_3") =  boolean1
Else
iProperties.Value("Custom", "Typ_3") =  Boolean2
End If
If you have questions please let me know.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
dgreatice
hi,
are this workflow?
1. Create rule ?
2. then Create UserParameter?
I got same error.
but if you change workflow
1. create UserParameter
2. then create rule, and capture all UserParameter.
its not showing error. I don't know its bug or what else.
my screencast are pending, you can see at:
http://autode.sk/2DlXgcT
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 11
bradeneuropeArthur
if all parameters and custom properties are defined then this give no error.
I assume that this is the case.
Seems to be buggy what you showed.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
martinhoos
Hello dgreatice,
i did it your way - but it didnt run. Please check the sample part.
Thank you very much.
Regards Martin
Message 6 of 11
dgreatice
I'm sorry @martinhoos
I cant open higher version. I using inventor 2014.
Message 7 of 11
bradeneuropeArthur
boolean1 = True
boolean2 = False
MsgBox (Typ)
Parameter.Param("Typ_1").Value = boolean1
Else
Parameter.Param("Typ_1").Value = Boolean2
End If
Parameter.Param("Typ_2").Value = boolean1
Else
Parameter.Param("Typ_2").Value = Boolean2
End If
Parameter.Param("Typ_3").Value = boolean1
Else
Parameter.Param("Typ_3").Value = Boolean2
End If
I have tested and this works.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
martinhoos
Thank you very much - your code is running.
Regards Martin
Message 9 of 11
aronmatheus
How is take the part number the side forms how the consequence the dimensions I chose in form?
Message 10 of 11
martinhoos
Hello Aron,
sorry, but i didnt understand your question.
Regards from Germany
Martin
Message 11 of 11
aronmatheus
Hi, Martin! I would like to change a dimension in the form there the consequence change a part number to the same form, to show when I change the dimensions see what part I'm chosen.
