BOM Sort not working Properly
Message 1 of 12
Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
   Dim oAssydoc As AssemblyDocument
   Set oAssydoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
   Dim oBOM As BOM
   Set oBOM = oAssydoc.ComponentDefinition.BOM
   oBOM.StructuredViewEnabled = True
   oBOM.StructuredViewFirstLevelOnly = False
   Dim oBOMView As BOMView
   Set oBOMView = oBOM.BOMViews.Item("Structured")
   Call oBOMView.Sort("BOM Structure", True, "Part Number", True, , True)
The above line not working properly, It sorts only the first a criteria i.e. BOM Structure. And if change the first one to Part Number the only the part number will work. At any point of time only the first sorting criteria is working.
Replies (11)
Message 2 of 12
Is this a bug or something wrong in the above code?
Message 3 of 12
xiaodong_liang
Autodesk Support
Autodesk Support
firstly, there is a typo in the last line. The TertiaryColumnTitle  is not set, while the TertiaryColumnAscending is set to true.
But this is not a problem. Even though I use Call oBOMView.Sort("BOM Structure", True, "Part Number", True), the issue can reproduce. The second column is not sorted.
I logged this issue with the engineer team.
Message 4 of 12
Thanks, Please Let me know if this is solved in upcomming updates.
Message 5 of 12
The problem exists in Inventor 2014 also.
Message 6 of 12
jdkriek
Good catch.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 7 of 12
mrattray
Still an "issue" in Inventor 2015.
Mike (not Matt) Rattray
Message 8 of 12
MechMachineMan
STILL an issue in 2016, 4 years later.
ie; Trying to sort BOM with a custom iProp column (Work Order #) sorted first, and mass sorted second.
Will sort mass just fine, but I can't set the option for what order to sort the custom iProp; it always sorts ascending even though it is completely numerical..
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 9 of 12
Still an issue in Inventor Pro 2017.... Can someone please fix this?!
Message 10 of 12
There is a way to sort BOM by more then one column:
Instead of trying to do it this way:
Do it this way: first sort by the second column and then by the first.
oBOMView.Sort("Part Number", True)
oBOMView.Sort("BOM Structure", True)
Message 11 of 12
Message 12 of 12
rhasell
Hi
Actually, this never works properly. You might get lucky, but don't bank on it. I guess it depends on your environment, but I had some strict sorting rules, and they never really worked consistently.
I have found that sorting in the drawing environment to be the most stable.
Create a dummy drawing and place all the Parts Lists in there. Using iLogic, you can sort multiple parts lists with a few mouse clicks.
These can then write back to the assemblies, and give a consistent BOM sort. (I wrote some code the other day to sort the BOM by item number, you cant go wrong with that one, LOL)
Reg
2026.1
