How to do boundarypatch on 3Dsketch circles in VBA?
I want to select all circles in the design to patch them. How do I do this in VBA? Drawing the circles is no problem.
Kind regards,
Bart
Vladimir.Ananyev
Could you please test this sample code. It works for me.
Private Sub BoundaryPatch_SketchCircle3D()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  'reference to 3d sketch
  Dim oSketch3d As Sketch3D
  Set oSketch3d = oDef.Sketches3D.Item(1)
  'create Boundary Patch Definition
  Dim oBoundaryPatchDef As BoundaryPatchDefinition
  Set oBoundaryPatchDef = oDef.Features _
        .BoundaryPatchFeatures.CreateBoundaryPatchDefinition
  'Add all 3D circles to Boundary Patch Definition
  'using Path object
  Dim oCircle3d As SketchCircle3D
  Dim oPath As Path
  For Each oCircle3d In oSketch3d.SketchCircles3D
    Set oPath = oDef.Features.CreatePath(oCircle3d)
    Call oBoundaryPatchDef.BoundaryPatchLoops.Add(oPath)
  Next
  ' Create the boundary patch feature based on the definition.
  Dim oBoundaryPatch As BoundaryPatchFeature
  Set oBoundaryPatch = oDef.Features _
        .BoundaryPatchFeatures.Add(oBoundaryPatchDef)
End Sub
 Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks a lot! That works perfectly the way I wanted!
would this be possible to do with a 3D sketch that is made up of triangles (check screenshot)? What do I have to pass to the boundary patch object for it to create the boundary patches, where these triangles are?
Omar
