BOM Cell Value - Decimal Places
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I need to find the total weight from the items listed in visible rows in parts list.
However, I find that the cell value for unit weight (see below) rounds up to an integer. I tried all possible options, but no success.
SyntaxEditor Code Snippet
oWeight_UNIT = oPartsList.PartsListRows.Item(i).Item("UNIT WT. (LB)").Value
Could someone help me. Thanks!
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Can you please send sample files to test?
Please make sure that files are non confidential.
In my system, Decimal places are displaying properly. For more details, refer below images.
Row 1Row 1Row 2Row 2Row 3Row 3
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
Is it possible that the precision in the model file (ipt or iam) is like (0) 226
and that the precision in the Partlist is different like (2) 226.50?
Than change the model precision...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
RoyWickrama_RWEI
Thanks. You are right. Even, I got the decimal places when I used this rule some times ago. I forgot it. I will check for the units precision for the weight.
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Check the units for weight.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
RoyWickrama_RWEI
Thanks for responding back. Thai is fine by now.
I am trying to retrieve the model units of measure from withing the drawing document (please see the part of coding below). But it does not go through!
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
oUOM_Mass = oModelDoc.unitsofmeasure.MassUnits
Last row of the above is wrong. Could I get this fixed? Thanks.
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code to get mass unit of Model document from Drawing document.
doc = ThisDrawing.ModelDocument
Dim oUnit As Inventor.UnitsTypeEnum
oUnit = doc.unitsofmeasure.MassUnits
Select Case oUnit
Case UnitsTypeEnum.kGramMassUnits
	messagebox.Show("Gram mass", "Mass unit")
Case Unitstypeenum.kLbMassMassUnits
	messagebox.Show("Lbs mass", "Mass unit")
Case UnitsTypeEnum.kKilogramMassUnits
	messagebox.Show("Kg mass", "Mass unit")
Case UnitsTypeEnum.kSlugMassUnits
	messagebox.Show("Slug mass", "Mass unit")
End Select
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
