Bitmap as browsernode icon loaded with black background
basautomationservices
Hi all,
I'm working on a tool where I need custom browser nodes. I made some icons in GIMP and now I'm trying to load them into the browser. It seems that whatever I do the image background becomes black.
I tried with a bunch of different icons, but the same keeps happening. Can this have anything to do with the conversion to IPictureDisp? That would mean the only workaround is to create the icons with the same backcolor as the browser?
Both an icon and a bitmap get the black background.
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Ralf_Krieg
Hello
Have you tried a magenta background?
EDIT: Magenta background will also not work.
R. Krieg
RKW Solutions
www.rkw-solutions.com
bradeneuropeArthur
Or use iconfx.portable with transparent backgrounds!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
The thing is my bitmap/icons do have transparent background. Either inventor does not support them or the IPictureDisp conversion doesn't.. When I use the same icons in the ribbon the background is transparent!
For now I think I'll go with my backup plan, creating them with the browser pane background color, and switching them according to dark/light mode.
Ralf_Krieg
Hello
Have tried it with one of my ICO icon files with transparent background, works as expected. Can you post one of your Icons?
EDIT: If I switch to dark mode, the background of light theme is used.
R. Krieg
RKW Solutions
Hi krieg,
sorry for the late reply. Somehow not getting email notifications for this topic.
Icon attached.
thomas.fullerD3PYA
I get the same thing, except the background is white. interestingly though, if you use the same icon in VBA, it has a transparent background
