Run multiple array lists with ability to skip to next
bbrumfield
bbrumfield
I have several array lists that do function as long as you make a selection. If you skip there is a failure message that says :
"Error in rule: Stock Sheet Material Stock Code List, in document: CadTalk_Test_3.ipt
Index was outside the bounds of the array."
As an example, I'd like to skip past Aluminum and select Galvanized or Steel etc. Which ever material in this case that is selected should create a custom property named "material stock code 1"
Dim oDoc As Document = ThisDoc.Document
Dim CustTypeALU As New ArrayList
CustTypeALU.Add(".063, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0003")
CustTypeALU.Add(".125, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0005")
CustTypeALU.Add(".090, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0007")
CustTypeALU.Add(".190, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0009")
CustTypeALU.Add(".050, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0013")
CustTypeALU.Add(".030, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0016")
CustTypeALU.Add(".080, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0017")
Dim oSelSheetMaterialStockCodeOpt1 As String = InputListBox("Select Sheet Material Stock Code",
	CustTypeALU, oSheetMaterialStockCodeOpt1, Title := "ALU Sheet Selection", _
	ListName := "ALU Sheet Stock Code")
sSplit = Split(oSelSheetMaterialStockCodeOpt1, "|")
oDesc = sSplit(0)
oPN = sSplit(1)
'if this custom property doesn't exist, this next line will also create it if needed (no error shown)
iProperties.Value("Custom", "Material Stock Code 1") = oPN
MsgBox(iProperties.Value("Custom", "Material Stock Code 1") )
Dim CustTypeGALV As New ArrayList
CustTypeGALV.Add("16GA, Sheet, Galvanneal Steel, 60.00 x 120.00 | ME-GALN-0001")
CustTypeGALV.Add("18GA, Sheet, Galvanneal Steel, 60.00 x 120.00 | ME-GALN-0002")
CustTypeGALV.Add("22GA, Sheet, Galvanneal Steel, 60.00 x 120.00 | ME-GALN-0003")
CustTypeGALV.Add("14GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0001")
CustTypeGALV.Add("16GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0002")
CustTypeGALV.Add("18GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0003")
CustTypeGALV.Add("24GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0004")
Dim oSelSheetMaterialStockCodeOpt2 As String = InputListBox("Select Sheet Material Stock Code",
	CustTypeGALV, oSheetMaterialStockCodeOpt2, Title := "GALV Sheet Selection", _
	ListName := "GALV Sheet Stock Code")
sSplit = Split(oSelSheetMaterialStockCodeOpt2, "|")
oDesc = sSplit(0)
oPN = sSplit(1)
Brent
A.Acheson
You can check the string value coming from the the input list box selection. Many ways to write this, check if it is Nothing, check if it has an empty string, or use the string function to return a boolean value.
If oSelSheetMaterialStockCodeOpt2 Is Nothing Then
MsgBox("Nothing Selected")
Else MsgBox(oSelSheetMaterialStockCodeOpt1) End If
If oSelSheetMaterialStockCodeOpt1 = Nothing Then
Else
If oSelSheetMaterialStockCodeOpt1 = "" Then
Else
If String.IsNullOrEmpty(oSelSheetMaterialStockCodeOpt1) = True Then
MsgBox("Nothing Selected") Else
String Check Code
If oSelSheetMaterialStockCodeOpt1 = Nothing Then 'can also use "" as an empty string instead of Nothing
Else
	oDesc = sSplit(0)
	oPN = sSplit(1)
If oSelSheetMaterialStockCodeOpt2 = Nothing Then
Else
oDesc = sSplit(0)
oPN = sSplit(1)
MsgBox(iProperties.Value("Custom", "Material Stock Code 1"))
Regards
Alan
bbrumfield
Hi A.Acheson,
Thank you! Worked exactly as needed.
Brent
