Base visibility of a drawing dimension on a parts parameter
w.poortinga
w.poortinga
Goodmorning,
I created a part with several parameters, driven by iLogic.
On the parts drawing I would like to hide a dimension based on a parameter I created in its part (a True/False parameter): true = visible and false = hidden. I can't seem to link to any of the parts parameters when in the drawing environment it seems.
I assume this is possible but I can't find how to do it. Would appreciate if anyone could point me in the right direction!
Thanks in advance.
EDIT: Alright. Found the paramter under Edit Rule -> x.dwg -> Sheet -> Viewx -> x.ipt -> parameters
So now the only thing I don't know how to do is hide that specific dimension on the drawing.
clutsa
There are many ways you could do this but the easiest off the top of my head would be to put that dimension on a custom layer and do
ThisDrawing.Document.StylesManager.Layers("CustomLayer").Visible = MyBooleanParameter
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
w.poortinga
Thanks, that worked great 🙂
