Pausing iLogic Rule during rule so that I can see a range.
Hi All,
My situation currently is that I have an angled constraint which I would like to run through a set values say from -10 to 10 degrees, then back to the starting position, However the path is not symmetrical, So on the way back I need to turn a few constraints off and a few on. So this means I cannot just drive the constraint.
My thinking was that I could Change the angle incrementally, then pause, then repeat, Thus making the motion easy to see, however I can't seem to find anyway to pause, or delay iLogic.
I am fairly familiar with iLogic and Coding so I thought this should be an easy function.
Any other suggestions are much appreciated,
Thanks In Advance for your help
Alex
