Pausing iLogic Rule during rule so that I can see a range.
11133SFW4P
11133SFW4P
Hi All,
My situation currently is that I have an angled constraint which I would like to run through a set values say from -10 to 10 degrees, then back to the starting position, However the path is not symmetrical, So on the way back I need to turn a few constraints off and a few on. So this means I cannot just drive the constraint.
My thinking was that I could Change the angle incrementally, then pause, then repeat, Thus making the motion easy to see, however I can't seem to find anyway to pause, or delay iLogic.
I am fairly familiar with iLogic and Coding so I thought this should be an easy function.
Any other suggestions are much appreciated,
Thanks In Advance for your help
Alex
11133SFW4P
After some digging I found this Delay Command for AutoCad LT, But I dont know what the inventor version is, https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Au...
philip1009
First off, I'll let you know that coding questions are better suited for the Inventor Customization forum, and I expect an Admin will move this post over there when they see it.
Is it the same constraints that are being turned on/off during the simulation?  You can control that in iLogic via:
SyntaxEditor Code Snippet
Constraint.IsActive("Mate:1") = True 'or False
Just make sure you turn off one set of constraints before turning others on, otherwise you'll get an error.
Inventor 2019 also offers more snippets for constraint/assembly control if that's the software your using.
