Axial alignment of holes
GeorgK
Advisor Advisor
Message 1 of 43
GeorgK
Hello together,
is there a way to calculate the axial alignment of holes to see if they fit?
Thank you very much
Georg
Replies (42)
Message 41 of 43
 I am currently working on a similar project. but I can't get the hole size checker to work hole alignment seem to work great and show in subfolder aligned and misaligned on side but there is nothing that says that hole sizes are with in spec. please help
SUB MAIN()
        Dim m_Inventor As Inventor.Application
        m_Inventor = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Dim oDoc As AssemblyDocument
        oDoc = m_Inventor.ActiveDocument
        Dim oCompdef As AssemblyComponentDefinition
        oCompdef = oDoc.ComponentDefinition
        Dim oBody1 As SurfaceBody
        Dim oBody2 As SurfaceBody
        oBody1 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select first body")
        oBody2 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select a body to compare")
        Dim oFace As Face
        Dim oAxis As WorkAxis
        For Each oFace In oBody1.Faces
            If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
                oAxis = oCompdef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector)
                Dim comparedFace As Face
                comparedFace = CompareFaces(oAxis, oBody2, oCompdef)
                If comparedFace Is Nothing Then
                    oAxis.Name = oAxis.Name & "_misaligned"
                Else
                    Dim oHoleFeature1 As HoleFeature
                    oHoleFeature1 = oFace.CreatedByFeature
                    Dim dia1 As Double
                    dia1 = oHoleFeature1.HoleDiameter.Value
                    dia1 = dia1 * 10 'Converting cm to mm
                    Dim oHoleFeature2 As HoleFeature
                    oHoleFeature2 = comparedFace.CreatedByFeature
                    Dim dia2 As Double
                    dia2 = oHoleFeature2.HoleDiameter.Value
                    dia2 = dia2 * 10 'Converting cm to mm
                    If Math.Round(dia1, 4) = Math.Round(dia2, 4) Then
                        Debug.Print("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Default")
                    ElseIf Math.Round(dia1, 4) >= Math.Round(dia2, 4) And Math.Round(dia1, 4) <= Math.Round(dia2, 4) + 0.5 Then
                        Debug.Print("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Special Type")
                    Else
                        Debug.Print("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => Not OK")
        Next
        Dim oPane As BrowserPane
        oPane = oDoc.BrowserPanes.ActivePane
        Dim alignedNodes As ObjectCollection
        alignedNodes = m_Inventor.TransientObjects.CreateObjectCollection
        Dim misAlignedNodes As ObjectCollection
        misAlignedNodes = m_Inventor.TransientObjects.CreateObjectCollection
        For i = 4 To oCompdef.WorkAxes.Count
            oAxis = oCompdef.WorkAxes.Item(i)
            Dim misaligned As Boolean
            misaligned = EndsWith(oAxis.Name, "misaligned")
            Dim oNode As BrowserNode
            If misaligned = True Then
                oNode = oPane.GetBrowserNodeFromObject(oAxis)
                misAlignedNodes.Add(oNode)
            Else
                alignedNodes.Add(oNode)
        Next
        Dim alignedAxes As BrowserFolder
        alignedAxes = oPane.AddBrowserFolder("Aligned Axes", alignedNodes)
        Dim misAlignedAxes As BrowserFolder
        misAlignedAxes = oPane.AddBrowserFolder("MisAligned Axes", misAlignedNodes)
    End Sub
    Public Function CompareFaces(ByVal oAxis1 As WorkAxis, ByVal oBody As SurfaceBody, ByVal compDef As AssemblyComponentDefinition) As Face
        For Each oFace As Face In oBody.Faces
                oAxis = compDef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector)
                If oAxis.Line.IsColinearTo(oAxis1.Line) Then
                    oAxis.Delete()
                    Return oFace
                    Exit Function
                Else
                    oAxis.Delete()
        Next
        Return Nothing
    End Function
    Public Function EndsWith(str As String, ending As String) As Boolean
        Dim endingLen As Integer
        endingLen = Len(ending)
        EndsWith = (Microsoft.VisualBasic.Right(Trim(UCase(str)), endingLen) = UCase(ending))
    End Function
Message 42 of 43
graypointsoftware
@GeorgK
I have just released my new app (Hole Check Lite) that does exactly this! Check it out on the App Store and let me know what you think.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=1768260766574491015
Message 43 of 43
gopinathmY575P
Hi sir, This code is working fine. But i need to check for an assembly which has multiple plate,pin,e.t.c?
is it possible to check like as interference checking
