Change Inventor Default Template location
tmo
tmo
Hello
In Inventor 2016 it was possible to set the default template location in the registry making it possible to manage the template path using group policies. I have upgraded to 2018 and are unable to find the default template location in the registry.
Anyone know where they put it?
Are you using vault? You are able to set the template location in the project file.
If you are not using vault could you set the location in Inventors application setting under the file tab. Then you can export / import these settings between PC's
Hope this helps
M
