Change drawing elements style & layer to "By Standard"?
bshbsh
bshbsh
Is there a way to programmatically change the style and layer of different drawing elements (drawing curves, balloons, dimensions, revision tables, etc.) to "By Standard" (as if it was done using the dropdown menus)? I know how to change them to the style/layer specified by the active standard, but I want to change them to "by standard" so if I change the active standard of a drawing, they change automatically. Or can't this be done?
frederic.vandenplas
I know for sure that some elements needs to be deleted, and replaced (with possible dataloss)
for example, you need to do this with tables (parts list, ...)
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
bshbsh
Yeah I know and I do that since I know no better way. That's why I asked. Is there really no way to do this through the API? Only through the gui?
AJK2010
I am also looking for this function to set dimensions back to By Standard (xxxxxx).
Is there stil no solution?
marcin_otręba
hi,
use:
            For i = 1 To odraw.StylesManager.DimensionStyles.Count
                If odraw.StylesManager.DimensionStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.DimensionStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.StandardStyles.Count
                If odraw.StylesManager.StandardStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.StandardStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.BalloonStyles.Count
                If odraw.StylesManager.BalloonStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.BalloonStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.CentermarkStyles.Count
                If odraw.StylesManager.CentermarkStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.CentermarkStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.FeatureControlFrameStyles.Count
                If odraw.StylesManager.FeatureControlFrameStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.FeatureControlFrameStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.HoleTableStyles.Count
                If odraw.StylesManager.HoleTableStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.HoleTableStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.LeaderStyles.Count
                If odraw.StylesManager.LeaderStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.LeaderStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.ObjectDefaultsStyles.Count
                If odraw.StylesManager.ObjectDefaultsStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.ObjectDefaultsStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.PartsListStyles.Count
                If odraw.StylesManager.PartsListStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.PartsListStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.RevisionTableStyles.Count
                If odraw.StylesManager.RevisionTableStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.RevisionTableStyles.Item(i).UpdateFromGlobal()
            Next
            Next
            For i = 1 To odraw.StylesManager.TableStyles.Count
                If odraw.StylesManager.TableStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.TableStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.TextStyles.Count
                If odraw.StylesManager.TextStyles.Item(i).UpToDate = False Then
                    odraw.StylesManager.TextStyles.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.Layers.Count
                If odraw.StylesManager.Layers.Item(i).UpToDate = False Then
                    odraw.StylesManager.Layers.Item(i).UpdateFromGlobal()
            Next
            For i = 1 To odraw.StylesManager.Styles.Count
                If odraw.StylesManager.Styles.Item(i).UpToDate = False Then
                    odraw.StylesManager.Styles.Item(i).UpdateFromGlobal()
            Next
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
engilic
Hi, @bshbsh and @AJK2010 did you find the solution?
