Suppress check out dialog on SaveAs
Skadborg.NTI
Message 1 of 8
Skadborg.NTI
On a Vaulted file:
If I use iLogic, ThisDocument.Document.SaveAs, then I am prompted to check out the original file (I am also prompted if I try so save via GUI).
Can this check out prompt be suppressed in the iLogic rule only? There are absolutly no reason to check it out and it disturbs the workflow:
Replies (7)
Message 2 of 8
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @Anonymous,
Inventor does provide an API ( ThisApplication.SilentOperation) to suppress most dialogs but I don't think it would work for this one.
Have you considered turning off that prompt manually. (Vault tab -> Vault Options -> Prompts ). Would that work for you?
Sajith
Sajith Subramanian
Autodesk Developer Network
Message 3 of 8
Skadborg.NTI
Correct - ThisApplication.SilentOperation does not suppress Vault dialogs.
I still want Inventor/Vault to prompt the user during normal operation. It is only when I call SaveAs that I would like to suppress the prompt, so turning the prompt off, as suggested unfortunately doesn't work for me.
Message 4 of 8
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @Skadborg.NTI,
In that case, unfortunately, there seem to be no Inventor API's for the Vault Addin.
Sajith
Sajith Subramanian
Message 5 of 8
And how about disabling or unloading the vault add-in like suggested here (last post)
https://forums.autodesk.com/t5/vault-customization/open-inventor-file-in-read-only-mode-not-check-ou...
Will this work ?
Message 6 of 8
sajith_subramanian
Autodesk Support
Autodesk Support
Hi Remy,
You could try to deactivate the vault add-in using inventor API's. Below is a link to a forum discussion that explains it more in detail:
https://forums.autodesk.com/t5/inventor-customization/deactivate-add-in-with-vba-or-vb-net/td-p/3642...
Let me know if you need more information.
Sajith
Sajith Subramanian
Message 7 of 8
Thanks Sajith,
That gave me an idea. Instead of messing with the registry, there is an easier way.
After Inventor has started, I deactivate the vault addin and after the job, I Activate it again and it works like a charm 🙂
ApplicationAddIn vadd = inventApp.ApplicationAddIns.ItemById["{48B682BC-42E6-4953-84C5-3D253B52E77B}"];
vadd.Deactivate();
Message 8 of 8
aspecchio
Not sure if it helps , but I use this
Dim addin As ApplicationAddIn = app.ApplicationAddIns.ItemById("{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}")
iLogicAuto = addin.Automation
iLogicAuto.RulesOnEventsEnabled = False
Then run your code
iLogicAuto.RulesOnEventsEnabled = True
