Automated Export Files
Hey all,
Ive been asked whether its possible to automate the process of exporting files through inventor. I have no real experience with righting scripts for Inventor (Im more of an AutoCAD person) so am looking for your guidance whether its possible then I will try and learn 🙂
We have had several files (.jt, .sat, etc) which we need exporting to .obj for us to use. We are basically wanting to drop the .jt file into a folder and it automatically exports to .obj.  I see this is highly unlikely without opening inventor (unless you tell me otherwise). So the next option would be to have a one click button after opening Inventor to export multiple files as .objs I guess.
I look for your thoughts as I dont really know where to start or if its worth it as exporting is pretty much a one-click after opening the file anyway.
Cheers,
Caroline
MechMachineMan
You can write script files that will open inventor, perform the necessary operations, and close inventor all with one click.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
