Automated draft workflow
breinkemeyer
breinkemeyer
I'm fairly new to Inventor programming (work extensively in Solid Edge).  I've been creating work points in assembly that I use later to add dimensions on the draft.  I'm sure I could do the same thing with points in the drawing view, but i'd rather get the point from the geometry in the drawing view.  Is this possible/preferred in Inventor?  Using C# here.
bradeneuropeArthur
What version of Inventor are you using?
In later editions you could use directly use Model dimensions here!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
