Automated assembly
Automated assembly
kv5053545
Automated assembly
kv5053545
Hi, I have been trying to automate assemblies in Autodesk inventor iLogic but it takes too long, and I would like to know if there is a way to automate without opening inventor or if there is something similar to AutoCAD core console.
bradeneuropeArthur
Can you give is an example of what you try to automate?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
kv5053545
hi @bradeneuropeArthur , I have a wall and what I do is to create copies of the original but editing length, width and thickness, but as many walls are created the process is very slow.
A.Acheson
Can you share the code your using for saving as and changing the parameter? Is the file creation slow or the qty of files created? It is unclear with your description of the issue where help is required.
Regards
Alan
