autodesk inventor 2018 student won't launch
Hi.
I need help. I just installed inventor 2018 student on my pc and it won't launch.
can anybody help me with ithis..
Mark.Lancaster
@Anonymous
First welcome to the community..
This forum is for customizing Inventor with applications/programs...  You should've posted over here.
However to answer your question..  Are you seeing the splash screen?  Have you updated your graphics card driver?
Mark Lancaster
Hi. yes the splash screen pops up and disappears and the graphics card driver is up to date. I turned off the antivirus on my pc when installing inventor.
After installing this error came up FPAV_rtp.sys.so I uninstalled F-Prot antivirus and reinstalled inventor again. No change.
Owner2229
Hey, did you install Inventor under an administrator user account? It's required in some cases.
You can also try this:
AIDA, the Autodesk® Installation Diagnostic Assistant
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
