Title Block Update
Title Block Update
donaldleigh
Title Block Update
donaldleigh
Hi everyone
I would like to update my title blocks for a project via Excel
Can someone please help me with an iLogic Rule?
What I’m trying to do is run the rule on a drawing.
I have an excel spreadsheet with all my data. The 1st Column has all the Data Names, IE Drawing Number, Client, Project ect. Each column after that is related to each drawing.
What I need is to have the rule look at the file name of the .IDW find that in the 1st row. Once found all the other data will be below that.
I have attached an example of the spreadsheet.
Also here is a rule that sort of works. This only get the data from the 2nd column. also need it to find the spreadsheet that is in the same folder as the drawing
Thanks heaps everyone
 SyntaxEditor Code Snippet
GoExcel.Open("S:\Projects\2017\17024 - Oxley Creek\17024-03\Project Data.xlsx", "Sheet1")
RowStart = 1
RowEnd = 100
For countA = RowStart To (RowEnd * 0.01) + RowStart
    If Not String.IsNullOrEmpty(GoExcel.CellValue("A" & RowEnd)) Then
        RowEnd = RowEnd + 100
    Else
        Exit For
Next
For rowPN = RowStart To RowEnd
    If String.IsNullOrEmpty(GoExcel.CellValue("A" & RowPN)) Then
    rowN = rowPN - 1
    Exit For
Next
For oRow = RowStart To RowN
    Dim oName As String = GoExcel.CellValue("A" & oRow)
    iProperties.Value("Custom", oName) = GoExcel.CellValue("B" & oRow)
Next
GoExcel.Close
InventorVb.DocumentUpdate()
Have you tried the GoExcel.FindRow functions?
"i" would be the row number to pull all the other data from.
You'll also need to set up GoExcel.TitleRow which is the row number with all your column names in it, and GoExcel.FindRowStart, which is the row number of the first row with data in it, in order for the FindRow function to work correctly.
i
= GoExcel.FindRow("filename.xls", "Sheet1", "Data Names", "=", ThisDoc.FileName(False))
Hope this helps,
Dave
MechMachineMan
Here is a rule that will update the ACTIVE document if it's file name is found in the spreadsheet. Anything additional between the "\" and the "." of the file name will cause it to not be found.
This method completely skips using iLogic and instead uses a LateBound Instance of Excel to perform the search and fetch the info.
The added sub acts to change the custom iProps because they will fail if you try to change the value when it doesn't exists, so it gets a little messy trying to do that without creating an additional sub to clean up the code. YOU SHOULD NOT HAVE TO TOUCH ANYTHING WITHIN the ChangeCustomProp sub.
Additionally, if there are any other iProps you need to change to, please follow this link and tweak as outlined in there.
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Note: to do this, all you should have to do is change the fields "Design Tracking Properties" and "Project" within sub main.
Finally, before writing this code, I took your excel file and transposed the data in it so each "property" is now in it's own column, and the file names are all listed in Column A, with the respective info for that file in the following column.
Good luck.
Sub Main()
'Excel Initialization
	oFile = "C:\Users\Desktop\Project Data.xlsx"
	oSheet = "Sheet1"
	oRowStart = 2
	xlApp = CreateObject("Excel.Application")
	xlwb = xlApp.WorkBooks.Open(oFile)
	xlws = xlwb.Worksheets(oSheet)
	With xlws
		oRowEnd = .Cells(.Rows.Count, 1).End(-4162).Row  'xldirection.xlup
	End With
'Process inventor file
	Dim oDoc As Document
	oDoc = ThisDoc.Document
	oInvFileName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
'Iterate through each row
	For RowNumber = oRowStart To oRowEnd
'Compare Row to File name
		If xlws.Cells(RowNumber,1).Value = oInvFileName Then
			oFound = True
			ChangeCustomProp(oDoc, "Drawing Number", xlws.Cells(RowNumber, 2).Value)
			ChangeCustomProp(oDoc, "Job Number", xlws.Cells(RowNumber, 3).Value)
			ChangeCustomProp(oDoc, "Title 1", xlws.Cells(RowNumber, 4).Value)
			ChangeCustomProp(oDoc, "Title 2", xlws.Cells(RowNumber, 5).Value)
			ChangeCustomProp(oDoc, "Title 3", xlws.Cells(RowNumber, 6).Value)
			oDoc.PropertySets("Design Tracking Properties")("Project").Value = xlws.Cells(RowNumber, 7)
			ChangeCustomProp(oDoc, "Client", xlws.Cells(RowNumber, 8).Value)
	Next
	If oFound = False Then
		MsgBox("Name of this file not found in file name column!" & vbLf & _
			   "File Name Searched For: " & oInvFilename)
	xlApp.Quit
	xlApp = Nothing
	oDoc.Update
End Sub
Sub ChangeCustomProp(Doc As Document, PropName As String, Value As String)
	Dim oCustomPropSet As Inventor.PropertySet
	oCustomPropSet = Doc.PropertySets("Inventor User Defined Properties")
	On Error Resume Next
		oCustomPropSet.Item(PropName).Value = Value
	If Err.Number <> 0
		oCustomPropSet.Add(Value, PropName)
Err.Clear End If End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
