Installation & Licensing
AIDA, the Autodesk® Installation Diagnostic Assistant
26 REPLIES 26
Message 1 of 27
asburyj
18503 Views, 26 Replies
We are proud to announce the release of the Autodesk® Installation Diagnostic Assistant. If you have received a “Some products Failed to install” message after running the installer for an Autodesk software, AIDA can read your installation log files and provide assistance in identifying the root cause and providing a suggested solution. You can find more information about this tool as well as a download link in the article linked below.
www.autodesk.com/aida
Jeffry Asbury
26 REPLIES 26
Message 2 of 27
Darin.Green
in reply to: asburyj
Nice work!
EDIT:
It would be better if you could add links to suggested solutions by integrating the Ottobot into the diagnostics process. Smiley Wink
If this information was helpful, please consider using the Accept Solution
Message 3 of 27
asburyj
in reply to: Darin.Green
Good suggestion. While OTTO wasn't directly integrated into AIDA, many of the solutions that appear in AIDA were leveraged from the OTTO solution database.
Jeffry Asbury
Message 4 of 27
h.schoenberger
What do I do when even the AIDA installer fails with Error code 2203 ?  (win 10 home)
Message 5 of 27
That's a windows error which means there a permission issue. Try the following solution Here
Message 6 of 27
Thanks, but this link did not help.
I have started a new forum thread in Installation & Licensing as this seems to be more complex.
Message 7 of 27
This doesn't work for me. I really need a solution to the instillation problem.
Here is a copy of the log from Notepad. Please see attached.
Thanks in advance.
Message 8 of 27
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, one they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
Message 9 of 27
asburyj
Hi Sanu.Amen
The error in your log is on the material library. The error reported is a download failure so I might suggest trying one of the other download methods such as browser download. If you continue to have issues I would advise you to start your own new thread here in the  I&L forum and post the full zipped set of logs that AIDA was able to pull for you.
2016/8/22:12:33:50 Sanu Nefer Amen DESKTOP-F90LJ90 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
Jeffry Asbury
Message 10 of 27
All I keep getting is this.
Message 11 of 27
Mark.Lancaster
@Anonymous
It appears the link to Acad LT 2017 is broken on the Virtual Agent.  @Darin.Green do you have download copy laying around?
Mark Lancaster
Message 12 of 27
Darin.Green
Use the following link:
AutoCAD LT 2017
Message 13 of 27
Because of the cost of valuable pogram , i urgently appeal to this medium, using the right to be student of revit soware.Gretings from Peru.
Message 14 of 27
Mark.Lancaster
@Anonymous
Welcome to the community..
What does your posting have to do with the AIDIA?  In the future please create your own posting and not hi-jack another one that has nothing to do with your needs.
Are you asking us the permission to use the student license of Revit?  We are only users here assisting other users.   Go create an Educational Account and request Revit.   As a reminder this free license can only be used for learning and training purpose..  It can't be used to create information that will be used in a commercial aspect and/or gain from it (meaning monetary).
Mark Lancaster
Message 15 of 27
Dear AIDA people,
I can't successfully run AIDA on my WINDOWS 10. After a clean installation, AIDA produces the error message you can see in picture.
It's related to the lack of python which I know is not installed in my system. Should it be part of the AIDA distribution?
I'd like to use AIDA to discover why AutoCAD 2017 does not install in my WINDOWS 10 machine, as you can see frommy post
http://forums.autodesk.com/t5/installation-licensing/free-trial-2017-does-not-install-on-my-windows1...
Emanuele
Message 16 of 27
Mark.Lancaster
@Anonymous
There's no such thing as AIDA people..  Smiley Very Happy
To resolve the AIDA issue, delete as many files and folders in your temp directory (which is normally located here C:\Users\<username>\Appdata\local\temp>)  Appdata is a hidden folder and you may need to adjust your viewing settings.    Or a fast way to access that location is per this.
Mark Lancaster
Message 17 of 27
@Anonymous
You may also just want to start a new posting and post your installation log file there.   We can review it with the need of AIDA and point you in the right direction if you like.
Mark Lancaster
Message 18 of 27
in reply to: Mark.Lancaster
Dear Mark,
thanks for your help. Unfortunately I still have the same error after deleting most of the files and dirs of %TEMP%
Message 19 of 27
Mark.Lancaster
@Anonymous
Like I said create a new posting (meaning do not reply here) and tell us what product/version and attach your log file.   Just make sure your installation log file doesn't contain any personal info such as your serial # (before you share it).  Smiley Wink   I will tell you it will be much faster if you did it this way.
Mark Lancaster
Message 20 of 27
Unfortunately in %TEMP% there are NO log file related to the installation of AutoCAD!
Administrator Productivity
