Auto dimension of assembly drawing having same pattern of dimensions
My task is to create general arrangement drawings. Assembly varies according to required components at top with  size.
Pattern of drawing dimension always remain same that is points from where we have to capture dimension is same for all sizes.
Like: Top to bottom dim, Center to top, center of one accessory to other's center.
Is there any way we can fix and automate so that dimension automatically get captured from set pattern at same location and every-time parts are changed i don't need to redraw it.
Is it possible to give work-point on parts and then through iLogic derive linear dimension from one point to another automatically?
Please do share your ideas how can we achieve this. Thanks in advance.
 @Anonymous  @kelly.young  @Anonymous  @JDMather @mcgyvr  @Cadmanto  @jtylerbc @BDidit  @blair  @karthur1
Cadmanto
Welcome to the forum.
Couple thoughts.  Maybe make a template drawing resembling your GA with the model in it.
Next possibly make this assembly an iAssembly and have the said dimensions in your member table.
Can you chart the dimensions in a table?  With the dimensions on the parts showing an "A" , "B" "C" etc.
I don't know iLogic well, so I cannot help you there.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Thanks, yes this is surely a feasible solution but in my case already components and assembly are ready and those are independent from each other. It will be more challenging if now i go for iAssembly . And representing dimension with A,B and C is last option if not got success in any other way.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Check out this link about Named Faces and using iLogic to dimension them.
iLogic create dimension using named geometry in idw
Where is New Feature Face Name in Inventor 2019 API located
Geometry Labels - Inventor 2019
Hope that helps!
Please select the Accept Solution button if a post solves your issue or answers your question.
I used below code by Assigning Name to edges.It ran successfully if assembly has only 1 component but getting error (as below) when 2 or more component in assembly.
Please help me to debug it.
Code is as below:
Sub CreateAutoDim()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'Refrence active sheet
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
'Reference the view we want
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(1)
'Reference Assembly
Dim oAssembly As AssemblyDocument
Set oAssembly = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oGeneralDims As GeneralDimensions
Set oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
For i = 1 To oAssembly.ReferencedDocuments.Count
MsgBox i
Set oModelDoc = oAssembly.ReferencedDocuments.Item(i)
Dim Edge1 As Edge
Set oObjs = oModelDoc.AttributeManager.FindObjects("*", "*", "Top")
Set Edge1 = oObjs.Item(i)
Dim Edge2 As Edge
Set oObjs = oModelDoc.AttributeManager.FindObjects("*", "*", "Bottom")
Set Edge2 = oObjs.Item(i)
Next
For Each Occurrence In oAssembly.ComponentDefinition.Occurrences
Set oCompOcc = Occurrence
Dim oOccEdge1Proxy As EdgeProxy
Dim oOccEdge2Proxy As EdgeProxy
Call oCompOcc.CreateGeometryProxy(Edge1, oOccEdge1Proxy)
Call oCompOcc.CreateGeometryProxy(Edge2, oOccEdge2Proxy)
Next
Dim aoDrawCurves1 As DrawingCurve
Set oDrawViewCurves = oView.DrawingCurves(oOccEdge1Proxy)
Set aoDrawCurves1 = oDrawViewCurves.Item(1)
Dim aoDrawCurves2 As DrawingCurve
Set oDrawViewCurves = oView.DrawingCurves(oOccEdge2Proxy)
Set aoDrawCurves2 = oDrawViewCurves.Item(1)
Dim GI1 As GeometryIntent
Set GI1 = oSheet.CreateGeometryIntent(aoDrawCurves1)
Dim GI2 As GeometryIntent
Set GI2 = oSheet.CreateGeometryIntent(aoDrawCurves2)
Dim Textpoint As Point2d
Dim XPos As Double
Dim YPos As Double
XPos = oView.Left - 3
YPos = oView.Top - (oView.Height / 2)
Set Textpoint = ThisApplication.TransientGeometry.CreatePoint2d(XPos, YPos)
Dim oDim1 As GeneralDimension
Set oDim1 = oGeneralDims.AddLinear(Textpoint, GI1, GI2)
End Sub
Below is link on video from where I taken the code:
https://www.youtube.com/watch?v=7_0YuPYmGyY&t=2177s
@kelly.young @Cadmanto @HermJan.Otterman @hozz__
