Where is New Feature Face Name in Inventor 2019 API located
Martin-Winkler-Consulting
Advisor Advisor
Message 1 of 13
I could not find the new Feature Property Face Name in the API.
Is anyone knowing where i could find it and how the property is named in the API?
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Replies (12)
Message 2 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@Martin-Winkler-Consulting,
Hoping that below suggestions in forum discussion may be helpful to read face name.
https://forums.autodesk.com/t5/inventor-customization/geometry-labels-inventor-2019/m-p/8350452#M904...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 13
clutsa
From what I can tell the feature property face name isn't new to the API it's the same stuff that's been there for years. The "new" part is simply that they added a user interface to make it easier to get to. The face names are stored using attributes and attributeSets.
Here's a rough idea how to get to them.
Dim part1Def As PartComponentDefinition = part1.Definition 'my part1 came from an assembly component occurrence
Dim oFaces As Faces = part1Def.SurfaceBodies(1).Faces
Dim tempFace As Face
For Each oFace In oFaces
	AttSets = oFace.AttributeSets
	If AttSets.NameIsUsed("iLogicEntityNameSet") Then
		AttSet = AttSets.Item("iLogicEntityNameSet")
		For Each Att In AttSet
			If Att.Value() = "yourNamedFeature" Then 'change name here
				tempFace = oFace
				Logger.Debug("tempFaceID Set" & tempFace.InternalName)
		Next
Next
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 4 of 13
@clutsa
Thanks, that was the hint I needed. I have written two examples in VBA how to get the names of all surfaces and how to get the names of selected surfaces. I need this in order to name a sketch according to the area from which it is originated.
Sub Get_AllNames_from_Faces()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oFaces As Faces
Set oFaces = oCompDef.SurfaceBodies(1).Faces
Dim AttSets As AttributeSets
Dim AttSet As AttributeSet
For Each oface In oFaces
 Set AttSets = oface.AttributeSets
  Set AttSet = AttSets.item("iLogicEntityNameSet")
    Debug.Print ("Face Value: " & Att.Value)
  Next
Next
End Sub
Sub Get_SelectedNames_from_Faces()
Dim CompDef As ComponentDefinition
Set CompDef = oDoc.ComponentDefinition
Dim oSelect As SelectSet
Set oSelect = oDoc.SelectSet
Dim oFaces As Faces
Set oFaces = CompDef.SurfaceBodies(1).Faces
For Each item In oSelect
 Set AttSets = item.AttributeSets
   If Att.Name = "iLogicEntityName" Then
    'Get only the displayed Name of the Face
  Next
Next
End Sub
Best Regards Martin
Martin Winkler
CAD Developer
Message 5 of 13
Hi All -
I'm trying to change the appearance (color) of a "named face" using iLogic.
For instance: "Face" = (Autodesk Appearance Library) Bamboo, "Back" = (Autodesk Appearance Library) Cardboard
Is this possible?
Actually, I'd like to be able to change the color of the "named face" by assigning a material to it....
Thanks.
Message 6 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to change appearance of named face (In this code, "Top" is considered as named face).
Sub Main()
	Dim oAsset As Asset
	oAsset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item("Cardboard")
	Dim oDocAsset As Asset
	Try
		oDocAsset = oDoc.AppearanceAssets.Item("Cardboard")
	Catch
		oAsset.CopyTo(oDoc)
	End Try
	Dim oFaces As Faces
	Dim oFace As Face
			    If Att.value = "Top" Then
					oFace.Appearance = oDocAsset
			  Next
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 13
That's brilliant, thanks.
Let's say that instead of "Cardboard", I need to reference the Appearance from a selected material?
I have a multi-level parameter (Top_Material) which is linked to the (Autodesk Material Library), where the user can select a material/appearance for the "Top".
So if the user selects Plaster, then the appearance for Plaster would be assigned.
Message 8 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Try below iLogic code to select the material from the list.
 Sub Main()
	Dim oList As ArrayList = New ArrayList()
	Dim oMaterial As Asset
	For Each oMaterial In ThisApplication.AssetLibraries.Item(2).AppearanceAssets
		oList.Add(oMaterial.DisplayName)
	Next
	If oDoc.DocumentType = kPartDocumentObject Then
		Dim oPartCompDef As PartComponentDefinition
		oPartCompDef = oDoc.ComponentDefinition
		Dim oParams As Parameters
		oParams=oPartCompDef.Parameters
		Dim oUserParams As UserParameters
		oUserParams=oParams.UserParameters
		Dim oAwesomeParameter As Parameter
		Try
			otester = oUserParams.Item("material")
		Catch
			oInsulationType=oUserParams.AddByValue("material", oList.Item(1), kTextUnits)
		End Try
	Parameter.Param("material").ExposedAsProperty = False
	Parameter.Param("material").IsKey = True
	MultiValue.List("material") = oList
	selected_mat = InputListBox("Choose Part material", MultiValue.List("material"),oList.Item(1), Title := "Part material", ListName := "Available Standard materials")
	Dim oAsset As Asset
	oAsset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item(selected_mat)
	Try
		oDocAsset = oDoc.AppearanceAssets.Item(selected_mat)
	Catch
		oAsset.CopyTo(oDoc)
	End Try
	Dim oFaces As Faces
	Dim oFace As Face
			  Next
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 13
MjDeck
@Martin-Winkler-Consulting , @Anonymous , @clutsa
Instead of going to the AttributeSets, you can use the NamedEntities iLogic API.
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(ThisDoc.Document)
Mike Deck
Software Developer
Autodesk, Inc.
Message 10 of 13
liminma8458
Hi, Mike,
Can I use this iLogic API in VB.NET in any way?
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
Message 11 of 13
MjDeck
Limin,
 Yes, you can access this and other iLogic API from VB.NET. Where is your code running?
1) add-in
2) external EXE
3) DLL loaded by iLogic
The best way to access it is different for each.
Mike Deck
Software Developer
Autodesk, Inc.
Message 12 of 13
liminma8458
Mike,
I want to use this iLogic API function directly from an Add-in of VB.NET (of course, I need to put the API as a reference somewhere in the add-in). So I don't need to put this function in an iLogic rule then call the rule first.
Limin
Message 13 of 13
MjDeck
Add references to these DLLs (in %ProgramFiles\Autodesk\Inventor 2019\Bin)
Autodesk.iLogic.Core.dll
Autodesk.iLogic.References.dll
Set the reference properties:
Copy Local : False
Specific Version : False
Then in your code:
Imports Autodesk.iLogic.Core
Imports Autodesk.iLogic.Interfaces
If (iLogicCentral.Instance IsNot Nothing) Then
	Dim iLogicAuto As IiLogicAutomation = iLogicCentral.Instance.ExternalApi
	'use iLogicAuto ...
If the iLogic add-in is loaded, then iLogicCentral.Instance shoudl be available.
Here's the documentation for IiLogicAutomation .
Mike Deck
Software Developer
Autodesk, Inc.
