Automate .ipt to adsk convertion
Message 1 of 11
Is there a way to automate .ipt to adsk conversion? I believe this can be done by ilogic or macro but I dont know how.
Replies (10)
Message 2 of 11
lmc.engineering
Hi @Anonymous
You can achieve this using the following:
SyntaxEditor Code Snippet
Dim oDoc As Document = ThisApplication.ActiveDocument
CompDef = oDoc.ComponentDefinition
FullFileName = "YourFilePath\YourFileName.adsk"
CompDef.BIMComponent.ExportBuildingComponent(FullFileName)
 If you go to Help>Programming/API Help and search 'BIMComponent', you'll find everything you need there.
Message 3 of 11
thank you @lmc.engineering. Do you know how to set the file name automatically to use the same as source name?
\YourFileName.adsk"
Message 4 of 11
lmc.engineering
You can use any of the below for this.
'''The below gets the file path and file name
Dim
FileSource As String = ThisDoc.PathAndFileName(False) ''' False leaves off the extension (ie .ipt)
'''The below gets just the file name Dim FileName As String = ThisDoc.FileName(False) '''False leaves off the extension
'''The below gets just the file path Dim FilePath As String = ThisDoc.Path
Message 5 of 11
It is not getting the file name, it write the code exactly as file name.
Message 6 of 11
lmc.engineering
Can you post what code you have and I'll take a look.
Message 7 of 11
FullFileName = "ThisDoc.FileName(False) 'without extension.adsk"
Message 8 of 11
lmc.engineering
Ok, so I can see where the confusion has come from. It was probably a bit misleading with the parameter 'FullFileName'. What we actually need is the file path and file name, as below
FullFilePathandName = ThisDoc.PathAndFileName(False)
FileFileName = FullFilePathandName & ".adsk"
Message 9 of 11
Hi @lmc.engineering.
Is it possible to have an option for ucs? I have consistent ucs name of each file.
Message 10 of 11
lmc.engineering
Hi @Anonymous
You can export a BIM component with a user coordinate system using the following:
Dim oBIMOrientType As BIMComponentOrientationTypeEnum
oBIMOrientType = kUserCoordinateSystemOrientationType
FullFileName = "C:\Temp\Test.adsk"
If you need to create and set the UCS before export, you can use this.
Sub Main()
CreateUCSBy3Points()
End Sub
Sub CreateUCSBy3Points()
    ' Set a reference to the PartComponentDefinition object
    Dim oCompDef As PartComponentDefinition
    oCompDef = oDoc.ComponentDefinition
    Dim oTG As TransientGeometry
    oTG = ThisApplication.TransientGeometry
    ' Create 3 workpoints to define the origin, x-direction and y-direction points
    Dim oWorkPoint1 As WorkPoint
    oWorkPoint1 = oCompDef.WorkPoints.AddFixed(oTG.CreatePoint(2, 0, 0))
    Dim oWorkPoint2 As WorkPoint
    oWorkPoint2 = oCompDef.WorkPoints.AddFixed(oTG.CreatePoint(4, 0, 0))
    Dim oWorkPoint3 As WorkPoint
    oWorkPoint3 = oCompDef.WorkPoints.AddFixed(oTG.CreatePoint(2, 2, 0))
    ' Create an empty definition object
    Dim oUCSDef As UserCoordinateSystemDefinition
    oUCSDef = oCompDef.UserCoordinateSystems.CreateDefinition
    ' Set it to be based on the 3 points
    Call oUCSDef.SetByThreePoints(oWorkPoint1, oWorkPoint2, oWorkPoint3)
    ' Create the UCS
    Dim oUCS As UserCoordinateSystem
    oUCS = oCompDef.UserCoordinateSystems.Add(oUCSDef)
	ExportBIM(oDoc)
End Sub
Sub ExportBIM(oDoc As Inventor.Document)
'Dim oDoc As Document = ThisApplication.ActiveDocument
End Sub
Is this what you were asking?
Message 11 of 11
AnJanson
Hi @lmc.engineering,
I found your solution, but I am pretty sure that it does not work.
Your code does not really set the OrientationType, the assignment is missing.
When I try to assign the OrientationType I get an exception.
I have already  created a thread:
https://forums.autodesk.com/t5/inventor-customization/export-rfa-with-ucs/td-p/9465092
Could you please do me a favor and check this issue?
Regards Andreas
