Inventor API Place Component and Constrain
Aydmatthew
Aydmatthew
I am trying to code something in Inventor API so when I place the part in an assembly, it prompts me to select the second selection of the constraint and repeat placing it until I tell it to stop. It is for screws so I don't have to select the same first selection each time, instead just keep selecting the second selection over and over again. I just have no idea where to start.
You can use Imate without code. Imate places part continuously like you want if  you add relationships but If you want to use  it with code you can check this link https://adndevblog.typepad.com/manufacturing/2013/03/hook-up-a-chain-using-imates.html
imate example vb.net code.
