Auto Accept Error Message
machiel.veldkamp
machiel.veldkamp
Is there a way to auto accept error messages?
I've looked at the EventManager and the UsedInterfaceEvents but I only see how to make new events and not how to modify  (or auto accept) existing events.
Any thoughts?
___________________________
Owner2229
Hey, it depends on what's the source of these messages.
E.g. If it's something from your code (e.g. a rule), you can simply use this:
ThisApplication.SilentOperation = True
'Your code
ThisApplication.SilentOperation = False
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
AlexFielder
Hi @machiel.veldkamp,
In theory, you *should* be able to run a rule such as this:
Sub Main()
Try
	'Do something here that might cause one of the following:
Catch ArgEx As ArgumentException
	MessageBox.Show("Caught an Argument Exception: " & ArgEx.Message, "Title")
Catch ComEx As COMException
	MessageBox.Show(Caught a COM Exception: " & ComEx.Message, "Title")
Catch Ex As Exception
	MessageBox.Show("Caught a general Exception: " & Ex.Message, "Title")
End Try
End Sub
The reality is that unless you tick the "Straight VB Code" button here:
iLogic complains that:
2017-03-31 13_17_08-Rule Compile Errors in TryCatchCatch, in TryCatchCatch.iLogicVb.png
Which doesn't help much.
I assume this is because iLogic only accepts the one Try Catch End Try...?
I guess you could just use a generic "Try Catch" and check the type of Exception:
Try
'do something here
Catch ex As Exception
	' Single catch block - catches as generic system exception
			'Process as FaultEx
	If TypeOf ex Is FaultException Then
	End If
			'Process as ArithEx
	If TypeOf ex Is ArithmeticException Then
	End If
			'Process as ArgEx
	If TypeOf ex Is ArgumentException Then
	End If
		'Cleanup
Finally
End Try
This way you can, as you put it "Auto Accept" certain Exception types and catch the rest.
Alex.
