Apprentice
Apprentice
mohamedtawakol12
Message 1 of 13
Apprentice
mohamedtawakol12
Hello I am trying to implement simple code using apprentice on VB.NET and the following error occurs
"System.Runtime.InteropServices.COMException: 'Retrieving the COM class factory for component with CLSID {C343ED84-A129-11D3-B799-0060B0F159EF} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).' "
I searched with the error and it showed me a solution to make sure inventor view is installed so I did install it again. but the error persists. And I checked the object viewer the object ApprenticeServerComponent is empty as shown with the attached picture. Can anyone please suggest a fix ?
Replies (12)
Message 2 of 13
bradeneuropeArthur
What version of Inventor are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
mohamedtawakol12
I am using inventor 2021 and i installed inventor viewer 2021 when trying to fix
Message 4 of 13
bradeneuropeArthur
have you removed older versions of Inventor?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 13
Michael.Navara
Usual mistake is bad compile settings. Application which uses Apprentice MUST be compiled as x64. Not x86 or AnyCPU with "Prefer 32-bit" option.
Message 6 of 13
bradeneuropeArthur
That is true!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 13
mohamedtawakol12
If i am using visual studio 2019 community , how can i make sure i am compiling on x64?
Message 8 of 13
mohamedtawakol12
Yes i had removed 2019
Message 9 of 13
Michael.Navara
Compile as x64
And this is my recommendation how to configure Autodesk.Inventor.Interop.dll
Message 10 of 13
mohamedtawakol12
Thank you very much this solves the first error, but sadly I encountered another error as you can see in the attached image. I am trying to change parameters with apprentice or is this not possible with apprentice ?
Message 11 of 13
Michael.Navara
This is not a bug, this is a feature.
In ApprenticeServer is available different set of functions and properties. Some of them is not implemented.
Usually Apprentice is used for manipulation with iProperties and document references. Manipulation with parametrs and other modeling features is not available.
Message 12 of 13
mohamedtawakol12
Ah, Thanks so I can't access parameters through apprentice ? From what I read on the Api help on apprentice that the top level objects are the big difference and other objects work fine is there a resourceI can learn more about apprentice from?
