Add a feature control frame to a dimension by iLogic
artemijs.nille
artemijs.nille
How to add a feature control frame to a dimension by iLogic (see picture below).
I already have an intent "AnsaugInnen"
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Blatt:1")
Dim Schnittansicht = Sheet_1.DrawingViews.ItemByName("B")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim AnsaugInnen = Schnittansicht.GetIntent("Sheet Metal (mm):2","AnsaugDKanteDSInnen")
theo.bot
artemijs.nille
my question was wrong.
I know how to create a fcf but i dont know how to attache it to dimension line.
In API sample they take a curve.
theo.bot
I don't have much experience with this, but this article might give you some direction. Solved: Add LeaderNote to Dimension using the API - Autodesk Community - Inventor
