Apprentice server component not working on Inventor 2019
I had a macro in vba Excel that worked fine with Inventor 2018 but now with the update to Inventor 2019, it seems that the module "Apprentice server" doesn't exists anymore (Run-time Error 'xxx-xxxxxxxx (8007007e)').
Here is my code (to change the workspace path of an existing design project):
Dim oIV As New ApprenticeServerComponent
Dim oProjectMgr As DesignProjectManager
Dim oproject As DesignProject
Set oProjectMgr = oIV.DesignProjectManager
Set oproject = oProjectMgr.DesignProjects.AddExisting(*path of my design project*)
oproject.WorkspacePath = *path of my desired workspace*
Thank you for your help.
Mathias
bradeneuropeArthur
Did you make the references to the interop correctly.
you need to use the inventor 2019 version of it stored under C:\Windows\Microsoft.NET\assembly\GAC_MSIL\Autodesk.Inventor.Interop\.....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hello Bradeneurope,
Thank you for your reply.
How can I be sure that the references to interop are correct?
I found multiples dll files in the folder that you indicates but I don't know what to do with it..
bradeneuropeArthur
look at the version in the references!
This should be like this for you:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\Autodesk.Inventor.Interop\v4.0_23.#.#.#__################\Autodesk.Inventor.Interop.dll.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
