Application Options Changed By Inventor
bradeneuropeArthur
Mentor Mentor
Message 1 of 1
bradeneuropeArthur
Why are the Application Options Changed when Using the..
dim a as Object = (thisapplication.CommandManager.Pick(selectionfilterenum.###,""))
If you have enabled the ApplicationEvent.OnApplicationOptionChange
Private Sub m_inventorApplicationEvents_OnApplicationOptionChange(BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_inventorApplicationEvents.OnApplicationOptionChange
This is always fired then.
The message is from my add in but shows that this option is changed.
An unwanted situation.
Question is why and for what reason.
@johnsonshiue Do you have any idea about it?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (0)
