API: Creating extrude problem
Jef_E
Message 1 of 11
Jef_E
Hi all!
I have this new problem, i'm trying to create a Surface extrude from a Arc.
My sketch has 3 Arc, and then i select the first Arc in it. This is the one i need to Extrude. But somthing i wrong with my code.. Don't know where the error is, as I have never done a Extrude feature..
My sample code:
        Dim oDoc As PartDocument = oInvApp.ActiveDocument
        Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
        Dim oArc As SketchArc = oDef.Sketches.Item("Segm_C02").SketchArcs(1)
        Dim oExtrudeDef As ExtrudeDefinition
        oExtrudeDef = oDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oArc, PartFeatureOperationEnum.kSurfaceOperation)
        oExtrudeDef.SetDistanceExtent("1000", PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
        oDef.Features.ExtrudeFeatures.Add(oExtrudeDef).Name = "Extrude"
What do i need to change?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (10)
Message 2 of 11
MechMachineMan
What error are you getting? Screenshot of both windows can be useful for helping determine what is wrong.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 11
Jef_E
Sorry for my late response.
This is the error i get on the posted code.
Can not convert COM object of type System .__ ComObject to interface type Inventor.Profile .
This operation failed because the QueryInterface call on the COM component for the interface with
IID { 8006A03A - ECC4-11D4-8DE9-0010B541CAA8 } failed with the
following error : No such interface supported (Exception from HRESULT: 0x80004002 ( E_NOINTERFACE ) ) .
Any ideas?
Inventor 2014 SP2
Message 4 of 11
MechMachineMan
Your syntax is wrong you are doing the equivalent of trying to assign a
string to am integer. That's what 'casting' as worded in the error means.
Justin K
Message 5 of 11
MechMachineMan
Justin K
Message 6 of 11
Jef_E
I don't get it.
the error is produced on this line:
But my oArc is as SketchArc? What is causing the error then? I don't see it..
Inventor 2014 SP2
Message 7 of 11
MechMachineMan
Are you passing the function a closed loop? If you can't do it manually...
you can't do it with API.
Justin K
Message 8 of 11
Jef_E
I can do i manually, thats why i want to automate it.
It's an arc that i want to extrude as surface, not as solid, so no it's not a closed loop.
I need this to create a thicken feature later in the program.
So i think for a surface i call
But it's not working for me.
Thanks for helping me!
Inventor 2014 SP2
Message 9 of 11
MechMachineMan
How do you know for sure it's that line giving issue?
Justin K
Message 10 of 11
Well, i think so because it highlights in visual studio? 😄
It could be that it gets a bad input.. But what?
Message 11 of 11
Jef_E
Found it, forgot to add for surface, didn't know that was needed. Will help me on my next step too!
Dim oSketch As PlanarSketch = oDef.Sketches.Item("Segm_C" & oBodyCount)
Dim oArc As SketchArc = oSketch.SketchArcs(1)
Dim oProfile As Profile = oSketch.Profiles.AddForSurface(oArc)
oExtrudeDef = oDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kSurfaceOperation)
Thanks for the help!
Inventor 2014 SP2
