- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I think the code to get the actual kFactor is not correct (and I don't mean my code is not correct but the API from Autodesk itself!).
I made a screencast to make it easier to explain.
- I have a part with a certain Sheet Metal Rule (3mm in my example).
- This Sheet Metal Rule uses the Unfold Rule (3mm_KFactor).
- The kFactor for this Unfold Rule is 0,1 ul.
- But in the Sheet Metal Defaults I say I want to use another Unfold Rule: Default_KFactor.
- The kFactor for this Unfold Rule is 0,5.
- If I use the vb code to get the kFactor I don't get the kFactor from the Unfold Rule I selected, but I get the kFactor form the Sheet Metal Rule I selected.
Is this a bug? Or did I do something wrong? Or is there another code to get the actual kFactor?
Dominiek
