Adjust the size of detail view circle
Message 1 of 11
Hi all,
I'm working on a project of automating drawings. When I try to generate with bigger dimensions, I get a problem as shown in the picture below (the circle of detail view B doesn't cover all the area necessary). I guess it is because that the size of detail view circle is an absolute value and not being scaled to A-A together. Is there any way to adjust the size/scale of detail view circle? Thank you so much!
Replies (10)
Message 2 of 11
bradeneuropeArthur
You need to constraint the sketch to the geometry. When the size changes the detail calout will also change.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
marcin_otręba
as Arthur wrote first of all fence must be attached to geometry.
To set radius use:
Dim drw As DrawingDocument = ThisDoc.Document
Dim detview As DetailDrawingView = drw.SelectSet.Item(1)
detview.FenceRadius=10
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 4 of 11
marcin_otręba
you can make it dependant from parent view :
detview.FenceRadius=detview.ParentView.Height/2
Ideas
or check my apps:
Message 5 of 11
@bradeneuropeArthur
Thank you for your reply!
Sorry for my ignorant question... but is "Constraint the sketch to the geometry" something different to attach? I tried this but the problem is I can choose only arcs, not the center of the rectangular section. And by this way, the size of detail view circle doesn't get scaled according to its parent view. Do I have to create a sketch in the view and set a constraint etc? Is there any tutorial / website that explains how to do that?
Message 6 of 11
robertast
@Anonymous
Attach to the wrong place. it is necessary to indicate not the center but the point of the model
Message 7 of 11
robertast
Video 😉
Message 8 of 11
robertast
I suppose the next question will be how to make the cross section do not fly off when the size changes 😉
Message 9 of 11
bradeneuropeArthur
Right mouse button edit sketch and constraints to the part.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 11
robertast
Arthur
I was trying to guess that minsuh.kim will have the next question like this one. And you answered ahead of time 😁
Message 11 of 11
bradeneuropeArthur
Hi @robertast
Now I see yes.
Problem I have in general is that this app is not mobile phone proof.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
