Adding Basic Dims Automatically
NachoShaw
Advisor Advisor
NachoShaw
Hey
Is there any code about to automatically add dims to drawing views? nothing too complicated, just need the X, Y (widest, tallest) dims. I am creating views automatically and would like to add the painstaking process to the end of it, i must have done about 500 of these today.....
cheers
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bradeneuropeArthur
Is there a possibility that you use parameters instead of dimensions, like in the picture?Dimension.PNG
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
NachoShaw
Hi
i had thought of that. In fact, i have written code to pretty much guarantee i can get the X,Y,Z of the part. not all parts are parameter driven they are part driven (created with the coexistence of other parts).
Unfortunately we have to show the dimension as a dimension edge to edge otherwise there may be ambiguity to the size and we can become responsible for anomolies / incorrect dims
cheers
Nacho
bshbsh
weird, there was a similar question not long ago.
Here a bit of code that retrieve the standard dimensions from all the views in the drawing. (the same function as annotate--> retreive model annotations)
also it looks at where the dimension is and places it accordingly.
If you have a lot of dimensions in all the sketches it wil also import these in the drawing.
Also, one downside to this function is that it cannot place dimensions in view 2 that are already in view 1....
Function RetreiveAnnotations(ByRef oBaseView As DrawingView, ByRef oView2 As DrawingView, ByRef oView3 As DrawingView, ByRef oView4 As DrawingView)
'function that retrieve dimensions from all views
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oDrawView As DrawingView
For Each oDrawView In oSheet.DrawingViews
	Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
	On Error Resume Next
	oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oDrawView)
Next
'next the location of every dimension is checked, and moved to the side of the view.
Dim dimension As GeneralDimension
Dim C1R As Integer = 0
Dim C1L As Integer = 0
Dim C1U As Integer = 0
Dim C1D As Integer = 0
Dim C2R As Integer = 0
Dim C2L As Integer = 0
Dim C2U As Integer = 0
Dim C2D As Integer = 0
Dim C3R As Integer = 0
Dim C3L As Integer = 0
Dim C3U As Integer = 0
Dim C3D As Integer = 0
	For Each dimension In oSheet.DrawingDimensions
	Dim dimy As Double = dimension.DimensionLine.midpoint.y
	Dim dimx As Double = dimension.DimensionLine.midpoint.x
	Dim tx As Double = dimension.Text.Origin.X
	Dim ty As Double = dimension.Text.Origin.Y
		If dimension.Type = kLinearGeneralDimensionObject Then
				If dimension.DimensionLine.direction.x = 0 Then
					'look at wich view the dimension is attached
					If dimy > oBaseView.Position.Y + (0.5 * oBaseView.Height) Then
						If dimx > oView2.Position.X + (0.5 * oView2.Width) + 1 Then
							'dimension connected to view4
						Else
							'dimension connected to view2
							If tx > oView2.Center.X Then
								C2R = C2R + 1
								MoveRight(oView2,dimension,C2R)
							ElseIf tx < oView2.Center.X Then
								C2L = C2L + 1
								MoveLeft(oView2,dimension,C2L)
					Else
						If dimx > oBaseView.Position.X + (0.5 * oBaseView.Width) + 1 Then
							'dimension connected to view3
							If tx > oView3.Center.X Then
								C3R = C3R + 1
								MoveRight(oView3,dimension,C3R)
							ElseIf tx < oView3.Center.X Then
								C3L = C3L + 1
								MoveLeft(oView3,dimension, C3L)
						Else
							'dimension connected to baseview
							If tx > oBaseView.Center.X Then
								C1R = C1R + 1
								MoveRight(oBaseView, dimension, C1R)
							ElseIf tx < oBaseView.Center.X Then
								C1L = C1L + 1
								MoveLeft(oBaseView,dimension, C1L)
			ElseIf dimension.DimensionLine.direction.y = 0 Then
					If dimx > oBaseView.Position.X + (0.5 * oBaseView.Width) Then
						If dimy > oView3.Position.Y + (0.5 * oView3.Height) + 1 Then
						Else
							If ty > oView3.Center.Y Then
								C3U = C3U + 1
								MoveUp(oView3, dimension, C3U)
							ElseIf ty < oView3.Center.Y Then
								C3D = C3D + 1
								MoveDown(oView3, dimension, C3D)
					Else
						If dimy > oBaseView.Position.Y + (0.5 * oBaseView.Height) + 1 Then
							If ty > oView2.Center.Y Then
								C2U = C2U + 1
								MoveUp(oView2, dimension, C2U)
							ElseIf ty < oView2.Center.Y Then
								C2D = C2D + 1
								MoveDown(oView2, dimension, C2D)
						Else
							If ty > oBaseView.Center.Y Then
								C1U = C1U + 1
								MoveUp(oBaseView, dimension , C1U)
							ElseIf ty < oBaseView.Center.Y Then
								C1D = C1D + 1
								MoveDown(oBaseView, dimension, C1D)
			Else
				'dimension not horizontal or vertical, is not moved
		ElseIf dimension.Type = kDiameterGeneralDimensionObject Then
'				'look at wich view the dimension is attached
'				If dimy > oBaseView.Position.Y + (0.5 * oBaseView.Height) + 1 Then
'					If dimx > oView2.Position.X + (0.5 * oView2.Width) + 1 Then
'						Trace.WriteLine("dimension connected to view4")
'						Trace.WriteLine(dimension.ModelValue)
'					Else
'						Trace.WriteLine("dimension connected to view2")
'					End If
'				Else
'					If dimx > oBaseView.Position.X + (0.5 * oBaseView.Width) + 1 Then
'						Trace.WriteLine("dimension connected to view3")
'					Else
'						Trace.WriteLine("dimension connected to baseview")
'					End If
'				End If
'this piece is not used, because the diameter dimensions are not moved.
	Next
End Function
Function MoveLeft(oView As DrawingView, dimension As DrawingDimension, Counter As Integer) '4 functions to move a dimension
Dim oTg = ThisApplication.TransientGeometry
Dim newX As Double
Dim newY As Double
Dim textHeight = 0.5
Dim deltaX As Double = (oView.Width * 0.5) + (0.6 * Counter)
newX = oView.Center.X - deltaX - textHeight
newY = dimension.Text.Origin.Y
dimension.Text.Origin = oTg.createpoint2d(newX,newY)
End Function
Function MoveRight(oView As DrawingView, dimension As DrawingDimension, Counter As Integer)
Dim newX As Double
Dim newY As Double
newX = oView.Center.X + deltaX
dimension.Text.Origin = oTg.Createpoint2d(newX,newY)
End Function
Function MoveUp(oView As DrawingView, dimension As DrawingDimension, Counter As Integer)
Dim newX As Double
Dim newY As Double
Dim texthieght = 0.5
Dim deltaY As Double = (oView.Height * 0.5) + (0.6 * Counter)
newX = dimension.Text.Origin.X
newY = oView.Center.Y + deltaY + textHeight
End Function
Function MoveDown(oView As DrawingView, dimension As DrawingDimension, Counter As Integer)
Dim newX As Double
Dim newY As Double
newY = oView.Center.Y - deltaY
End Function
 with credits to @Anonymous  who gave a lot of insparation on automated drawings in the following topic.
https://forums.autodesk.com/t5/inventor-customization/ilogic-coding-to-create-automated-drawing/m-p/...
JelteDeJong
hi, i created this rule. it only does not work when the most outer curve (line) is not a line or a (part of a) circle, but probally you are not using lines like splines that much.
Sub Main()
    Dim doc As DrawingDocument = ThisApplication.ActiveDocument
    For Each sheet As Sheet In doc.Sheets
        For Each View As DrawingView In sheet.DrawingViews
            Dim minCurveX As DrawingCurve = Nothing
            Dim minX As Double = 9999999999999
            Dim maxCurveX As DrawingCurve = Nothing
            Dim maxX As Double = -9999999999999
            Dim minCurveY As DrawingCurve = Nothing
            Dim minY As Double = 9999999999999
            Dim maxCurveY As DrawingCurve = Nothing
            Dim maxY As Double = -9999999999999
            For Each curve As DrawingCurve In View.DrawingCurves
                Dim geoType = curve.Segments.Item(1).GeometryType
                If (geoType <> Curve2dTypeEnum.kLineSegmentCurve2d And
                    geoType <> Curve2dTypeEnum.kCircleCurve2d) Then
                    ' I will will only search for curves that can be used for a dimension.
                    Continue For
                Dim curMinX = curve.Evaluator2D.RangeBox.MinPoint.X
                If (curMinX < minX) Then
                    minCurveX = curve
                    minX = curMinX
                Dim curMaxX = curve.Evaluator2D.RangeBox.MaxPoint.X
                If (maxX < curMaxX) Then
                    maxCurveX = curve
                    maxX = curMaxX
                Dim curMinY = curve.Evaluator2D.RangeBox.MinPoint.Y
                If (curMinY < minY) Then
                    minCurveY = curve
                    minY = curMinY
                Dim curMaxY = curve.Evaluator2D.RangeBox.MaxPoint.Y
                If (maxY < curMaxY) Then
                    maxCurveY = curve
                    maxY = curMaxY
            Next
            Dim intLeft = getMostLeftIntent(sheet, minCurveX)
            Dim intRight = getMostRightIntent(sheet, maxCurveX)
            Dim intBottom = getMostBottomIntent(sheet, minCurveY)
            Dim intTop = getMostTopIntent(sheet, maxCurveY)
            If (intLeft IsNot Nothing And intRight IsNot Nothing) Then
                Dim txtPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(
                    View.Position.X,
                    View.Position.Y + View.Height / 2 + 1)
                sheet.DrawingDimensions.GeneralDimensions.AddLinear(
                    txtPoint,
                    intLeft,
                    intRight,
                    DimensionTypeEnum.kHorizontalDimensionType)
            If (intBottom IsNot Nothing And intTop IsNot Nothing) Then
                    View.Position.X - View.Width / 2 - 1,
                    View.Position.Y)
                    txtPoint,
                    intBottom,
                    intTop,
                    DimensionTypeEnum.kVerticalDimensionType)
        Next
    Next
End Sub
Public Function getMostLeftIntent(sheet As Sheet, curve As DrawingCurve) As GeometryIntent
    Dim returnValue As GeometryIntent = Nothing
    If (geoType = Curve2dTypeEnum.kLineSegmentCurve2d) Then
        Dim startInt As GeometryIntent = sheet.CreateGeometryIntent(curve, PointIntentEnum.kStartPointIntent)
        Dim endInt As GeometryIntent = sheet.CreateGeometryIntent(curve, PointIntentEnum.kEndPointIntent)
        returnValue = If(startInt.PointOnSheet.X < endInt.PointOnSheet.X, startInt, endInt)
    ElseIf (geoType = Curve2dTypeEnum.kCircleCurve2d) Then
        returnValue = sheet.CreateGeometryIntent(curve, PointIntentEnum.kCircularLeftPointIntent)
    Return returnValue
End Function
Public Function getMostRightIntent(sheet As Sheet, curve As DrawingCurve) As GeometryIntent
        returnValue = If(startInt.PointOnSheet.X > endInt.PointOnSheet.X, startInt, endInt)
        returnValue = sheet.CreateGeometryIntent(curve, PointIntentEnum.kCircularRightPointIntent)
    Return returnValue
End Function
Public Function getMostTopIntent(sheet As Sheet, curve As DrawingCurve) As GeometryIntent
        returnValue = If(startInt.PointOnSheet.Y > endInt.PointOnSheet.Y, startInt, endInt)
        returnValue = sheet.CreateGeometryIntent(curve, PointIntentEnum.kCircularTopPointIntent)
    Return returnValue
End Function
Public Function getMostBottomIntent(sheet As Sheet, curve As DrawingCurve) As GeometryIntent
        returnValue = If(startInt.PointOnSheet.Y < endInt.PointOnSheet.Y, startInt, endInt)
        returnValue = sheet.CreateGeometryIntent(curve, PointIntentEnum.kCircularBottomPointIntent)
    Return returnValue
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
