VBA Marco background color
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 8
I want to make a marco that chance between 2 background color
I want it to run this code if the ColorSchemes is not Millennum
ThisApplication.ColorSchemes.Item("Millennium").Activate
        ThisApplication.ColorSchemes.BackgroundType = BackgroundTypeEnum.kImageBackgroundType
I want it to run this code if the ColorSchemes is not Presentation
ThisApplication.ColorSchemes.Item("Presentation").Activate
        ThisApplication.ColorSchemes.BackgroundType = 52737
And I only what to want to run the marco to make it happen ... .no dialog Box please
I got code form a coworker. but that force me to make the chose ... I want it to do it for me by reading what background is aktiv before hitting the marco. can you help
Replies (7)
Message 2 of 8
pball
I can't find a way to get the active color scheme so this isn't ideal but it seems to work. It is possible get the current value for the background type so a simple check of the current value lets you toggle the two color schemes.
    If (ThisApplication.ColorSchemes.BackgroundType = 52737) Then
    Else
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Message 3 of 8
aurel_e
Hi all,
I am using this code copied from this discussion(Inventor 2018):
Sub ChangeBackground()
        ThisApplication.ColorSchemes.Item("High Contrast").Activate
    Else
        ThisApplication.ColorSchemes.Item("Sky").Activate
End Sub
The problem is that I want to switch from a "Sky" color scheme with the "Background Image" (please see screenshot attached) and the macro is giving me a normal blu background. I don't know how to write it.
Message 4 of 8
    Else
is this what your want?
End If End Sub
Message 5 of 8
aurel_e
nearly there:
I'm using this now (trying to understand and messing around):
If (ThisApplication.ColorSchemes.BackgroundType <> kImageBackgroundType) And (ThisApplication.ColorSchemes.BackgroundType <> 52737) Then
        Else
    Else
End Sub
I don't like this 2 lines:
What I'm tryoing to say is : If the color scheme is neither Sky or High Contrast, activate "Sky".
Thanks.
Message 6 of 8
This is all your need I think..
Public Sub ChangeBackground()
If ThisApplication.ActiveColorScheme.Name = "High Contrast" Then
Stop
If ThisApplication.ActiveColorScheme.Name = "Sky" Then
Stop
Else
End Sub
Message 7 of 8
aurel_e
Hi BT,
the "stop" for same reason is not working.
I have changed it in:
Else
Else
End Sub
This is now fine!
Thank you for your support.
Message 8 of 8
Below is the code I use.  I use a grey gradient when I'm normally working, and then if I want to do a screenshot of something, I change the background to white.  Then I want to switch it back easily.  Only thing to note is the custom image file I made called "Plain white" and the folder location.  Edit those lines to match your setup.
Sub Background_Switch()
Dim oBackGroundType As BackgroundTypeEnum
With ThisApplication.ColorSchemes 'edit the application background settings easily
oBackGroundType = .BackgroundType
Dim oColorScheme As ColorScheme
Set oColorScheme = ThisApplication.ActiveColorScheme
If oBackGroundType = kGradientBackgroundType Then
oColorScheme.ImageFullFileName = "C:\Users\Public\Documents\Autodesk\Inventor 2019\Backgrounds\PLAIN WHITE.png"
Else
.BackgroundType = BackgroundTypeEnum.kGradientBackgroundType
End With
End Sub
