Add parameter in iLogic
machiel.veldkamp
machiel.veldkamp
Hey.
So I want to make a new parameter in some .ipt's that came from the frame generator.
I want to take the parameters from the frame generator and show them in my already existing inventor .idw partslist.
So I want this:
LENGTE = G_L
BREEDTE = G_W
DIKTE = G_H
I tried some preexisting code already but it doesn't seem to work since I want to add a parameter with the value of another parameter.
Any help on this would be helpfull 🙂
___________________________
MechMachineMan
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rossano_praderi
this link is a good example for create a new parameter
http://forums.autodesk.com/t5/inventor-customization/add-parameter-to-drawing-file-through-ilogic/td...
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
machiel.veldkamp
Hey thanks for the reply, I don't have those options in Inventor tho. Not that we are still using 2012 pro here.
machiel.veldkamp
Thanks Rossano,
I'll check it out!
