edit color of drawing layers with materials from parts
Hello
I just found this code for color of layer editing with material properties from part but it doesent work when i run the rule.
Sub Main
    drawDoc = TryCast(ThisDoc.Document, DrawingDocument)
    If (drawDoc Is Nothing) Then
       MessageBox.Show("This rule can only be run in a drawing,", "iLogic")
       Return
    ChangeLayerOfOccurrenceCurves()
End Sub
Private drawDoc As DrawingDocument
Public Sub ChangeLayerOfOccurrenceCurves()
    ' Process the occurrences, wrapping it in a transaction so the
    ' entire process can be undone with a single undo operation.
    Dim trans As Transaction
    trans = ThisApplication.TransactionManager.StartTransaction(drawDoc, "Drawing Layers by Materials")
    Try
        For Each dSheet As Sheet In drawDoc.Sheets
            For Each drawView As DrawingView In dSheet.DrawingViews
                ' Call the recursive function that does all the work.
                Dim docDesc As DocumentDescriptor
                docDesc = drawView.ReferencedDocumentDescriptor
                If (docDesc Is Nothing) Then Continue For
                If (docDesc.ReferencedDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject) Then Continue For
                Dim asmDef As AssemblyComponentDefinition
                asmDef = docDesc.ReferencedDocument.ComponentDefinition
                Call ProcessOccurrences(drawView, asmDef.Occurrences)
            Next
        Next
    Catch ex As Exception
        trans.Abort()
        Throw ex
    End Try
    trans.End()
End Sub
Private Sub ProcessOccurrences(ByVal drawView As DrawingView, _
   ByVal Occurrences As ComponentOccurrences)
    ' Iterate through the current collection of occurrences.
    Dim occ As ComponentOccurrence
    For Each occ In Occurrences
        If (occ.Suppressed) Then Continue For
        If (occ.Definition Is Nothing) Then Continue For
        ' Check to see if this occurrence is a part or assembly.
        If occ.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
            ' ** It's a part so get the material
            Dim subDoc As Document = occ.Definition.Document
            If (subDoc Is Nothing) Then Continue For
            Dim partDoc As PartDocument = subDoc
            Dim materialName = partDoc.ComponentDefinition.Material.Name
            ' Get the TransientsObjects object to use later.
            Dim transObjs As TransientObjects
            transObjs = ThisApplication.TransientObjects
            ' Verify that a layer exists for this material.
            Dim layers As LayersEnumerator
            layers = drawDoc.StylesManager.Layers
            On Error Resume Next
            Dim newLayer As Layer
            newLayer = layers.Item(materialName)
            If Err.Number <> 0 Then
                On Error Goto 0
                ' Copy an arbitrary layer giving it the name
                ' of the material.
                newLayer = layers.Item(1).Copy(materialName)
                ' Set the attributes of the layer to use the color,
                ' have a solid line type, and a specific width.
                '                    newLayer.Color = newColor
                newLayer.LineType = LineTypeEnum.kContinuousLineType
                'newLayer.LineWeight = 0.02
            On Error Goto 0
            ' Get all of the curves associated with this occurrence.
            Dim drawcurves As DrawingCurvesEnumerator
            drawcurves = drawView.DrawingCurves(occ)
            If Err.Number = 0 Then
                On Error Goto 0
                ' Create an empty collection.
                Dim objColl As ObjectCollection
                objColl = transObjs.CreateObjectCollection()
                ' Add the curve segments to the collection.
                Dim drawCurve As DrawingCurve
                For Each drawCurve In drawcurves
                    Dim segment As DrawingCurveSegment
                    For Each segment In drawCurve.Segments
                        objColl.Add(segment)
                    Next
                Next
                ' Change the layer of all of the segments.
                Call drawView.Parent.ChangeLayer(objColl, newLayer)
            On Error Goto 0
        Else
            ' It's an assembly so process its contents.
            Call ProcessOccurrences(drawView, occ.SubOccurrences)
    Next
End Sub
salariua
Bear in mind that these solutions tend to slow down inventor to a halt especially for large assemblies.
Here's some more info
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
