How to edit sheet description text
Milan_Nosil
Milan_Nosil
Hello everybody,
I need to edit "Bend Notes" text (string "DOWN,UP" picture below).
There are texts, witch I need to translate and edit to foreing language on .idw, For example: "Down" to "nach unten" and "Up" to "nach oben".
Do you happend to know if this default string "Down/Up" I can find in some .xml configuration file.
Or is it possible to manage it with another way?
Thank you for advice.
adam.nagy
Autodesk Support
Autodesk Support
Hi Milan,
I don't think this has been implemented yet, though the idea itself got accepted:
http://forums.autodesk.com/t5/inventor-ideastation/optional-quot-bend-note-quot-according-to-languag...
The only option might be to install the language pack that you need the word to be in.
Cheers,
Adam Nagy
Autodesk Platform Services
