Attached is a PDF screen shot.
I found this code online for an iLogic routine. The line for formatting the text has "<DimensionValue/>", which is a code to maintain the dimension value. This helps a lot. Now I just need the "<???/>" code for GAUGE. I see in this code that "<br/>" does a return to next line. So, I'm assuming that GAUGE has a similar code.
'get model document (part or assembly) from the parent DrawingDocument
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'save text parameter "MyText" value in the string variable Value
Dim Value As String = Parameter(modelName, "MyText")
'Note: this string Value could be read from any source (e.g., excel sheet).
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oSSet As SelectSet = oDoc.SelectSet
If oSSet.Count = 0 Then
MessageBox.Show("Select at least one dimension please", "DIM", _
MessageBoxButtons.OK,MessageBoxIcon.Information)
Else
For Each obj As Object In oSSet
'filter dimensions, ignore other selected entities
If TypeOf obj Is GeneralDimension Then
'reference to the selected dimension
Dim oDim As GeneralDimension = obj
'refrence to the DimensionText object
Dim oDimensionText As DimensionText = oDim.Text
'change dimension text
oDimensionText.FormattedText = "<DimensionValue/>" & "<br/>" & Value
Next
Beep
