Surface Pattern
Surface Pattern
Surface Pattern
 Hello Community,
Try to explain what I like to do:
For my Project I need to create a kind of pattern, of an Element (Surface,extrusion etc.) along the hole Body of an Part.
I need a Body which is completely perforated with this Element. (for example rectangular every 25x25mm an Element)
This is quite an easy Task, if the surface where placed on is flat or curved in one direction, you can solve it with the common pattern functions.
I have a surface (or body) which is freeform, two directions. (Spline)
Is there a way to do that? Placing every Element normal or in defined angle to this surface?
May can I try to first place a grid of points on that surface, and then proceed further?
Any way to do this via API?
Thanks for Help
Greetings from Austria
Simon
HermJan.Otterman
place sketchpoints on the spline
create workaxis through the points, perpendicular to the surface (select point and surface)
use this workaxis for creation of you holes
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
