Add card to the Sheet Metal Defaults
We work with a lot of card and it would be very useful to have card in the sheet metal default option bit, I've realised that adding card to library allows me to do this, but I have Card-445 as the only option- what sort of card is this?
Also I'm not sure whether the Default_KFactor is what I want and whether any of the other options would be better?
The same goes to the bend and corner options.
Anyone have any advice?
MechMachineMan
What do you mean by Card? I have never heard of this before.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
As in thick paper- not like cardboard, but like the stuff cereal boxes are made form. This is what I need.
