Acquire Vault Files with Inventor API
machiel.veldkamp
Message 1 of 26
machiel.veldkamp
Hi!
I'm looking for a way to 'Get' files from the Vault with iLogic
What I have so far:
All my wanted files are in a VBA Dictionary stored as Filename.extension
Imports System.Text
Imports System.IO
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports Autodesk.Connectivity.WebServices
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports ACW = Autodesk.Connectivity.WebServices
Imports AWS = Autodesk.Connectivity.WebServices
Imports VB = Connectivity.Application.VaultBase
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Properties
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
AddReference "Connectivity.Application.VaultBase.dll"
AddReference "Autodesk.Connectivity.WebServices.dll"
For i = 0 To oTotalDict.Count - 1 'oTotalDict(String(C:/path/.../filename.extension), Int(QTY))
		'oCount = oTotalDict.Values(i)
		Key = oTotalDict.Keys(i)
		dwgPath = Left(key, Len(Key) - 3) & "dwg"
		VaultPartPath = Key.Replace("C:\Company\Vault\", "$/")
		VaultPartPath = VaultPartPath.Replace("\", "/")
		VaultDWGPath = dwgPath.Replace("C:\Company\Vault\", "$/")
		VaultDWGPath = VaultDWGPath.Replace("\", "/")
		Dim VaultDWGPaths() As String = New String() {VaultDWGPath }
		Dim VaultPartPaths() As String = New String() {VaultPartPath }
		Dim wsFiels() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultDWGPaths)
		Dim wsFiels2() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPartPaths)
		'Ts file exists in the Vault.
		Dim DwgFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn, wsFiels(0)) 		'DWG HERE
		Dim PartFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn, wsFiels2(0)) 	'PART HERE (IPT/IAM)
		Dim lifeCycleInfo As VDF.Vault.Currency.Entities.FileLifecycleInfo = DwgFileIt.LifecycleInfo
		Dim DWGIsCheckedOut As Boolean = DwgFileIt.IsCheckedOut
		Dim PartIsCheckedOut As Boolean = PartFileIt.IsCheckedOut
		If DWGIsCheckedOut = True
			Trace.WriteLine("CHECKED OUT: " & dwgPath)
		Else If PartIsCheckedOut = True
		Trace.WriteLine("CHECKED OUT: " & Key)
		If Not lifeCycleInfo.StateId = - 1 'IN VAULT
			'Trace.WriteLine("File not in C?: " & dwgPath)
			If System.IO.File.Exists(dwgPath)
				'Trace.WriteLine("YES IN VAULT, YES ON C: " & dwgPath & " Status: " & lifeCycleInfo.StateName)' & " ID:" & lifeCycleInfo.StateId)
			If Not System.IO.File.Exists(dwgPath)
				Trace.WriteLine("YES IN VAULT, NOT ON C: " & dwgPath & " Status: " & lifeCycleInfo.StateName)' & " ID:" & lifeCycleInfo.StateId)
		If lifeCycleInfo.StateId = - 1 'FILE NOT IN VAULT.
			'Trace.WriteLine("File not in Vault?: " & dwgPath)
				Trace.WriteLine("ON C, NOT IN VAULT: " & dwgPath & " Status: " & lifeCycleInfo.StateName)' & " ID:" & lifeCycleInfo.StateId)
				'Trace.WriteLine("NOT ON C, NOT IN VAULT: " & dwgPath & " Status: " & lifeCycleInfo.StateName)' & " ID:" & lifeCycleInfo.StateId)
		'MessageBox.Show(lifeCycleInfo.StateName)
	Next
I want to get the files that are not on C but are located in the Vault.
I found some topics that might be interesting but I don't know how to get the files themselves yet.
https://forums.autodesk.com/t5/inventor-customization/i-made-a-ilogic-version-checker-for-my-colleag...
https://forums.autodesk.com/t5/inventor-customization/ilogic-open-file-from-vault/td-p/5701827
https://adndevblog.typepad.com/manufacturing/2019/04/connecting-vault-and-accessing-vault-file-statu...
Anyone that knows how to get a file from vault just from the fullpathname?
The Vault API Help gives this example but I don't know how to use it.
Public Sub DownlodFiles(fileIters As ICollection(OfVDF.Vault.Currency.Entities.FileIteration))
       ' download individual files to a temp location
       Dim settings As NewVDF.Vault.Settings.AcquireFilesSettings(m_conn)
       settings.LocalPath = NewVDF.Currency.FolderPathAbsolute("c:\temp")
       For Each fileIter AsVDF.Vault.Currency.Entities.FileIteration In fileIters
              settings.AddFileToAcquire(fileIter, _ _
              VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download)
       Next
       Dim results As VDF.Vault.Results.AcquireFilesResults = _
           m_conn.FileManager.AcquireFiles(settings)
End Sub
Public Sub DownloadAssembly(topLevelAssembly AsVDF.Vault.Currency.Entities.FileIteration)
       ' download the latest version of the assembly to working folders
    settings.OptionsRelationshipGathering.FileRelationshipSettings.IncludeChildren = True
    settings.OptionsRelationshipGathering.FileRelationshipSettings.RecurseChildren = True
    settings.OptionsRelationshipGathering.FileRelationshipSettings.VersionGatheringOption = _
           VDF.Vault.Currency.VersionGatheringOption.Latest
       settings.AddFileToAcquire(topLevelAssembly, _
End Sub
Public Sub DownloadDialog(fileIter AsVDF.Vault.Currency.Entities.FileIteration, _
    parentWindowHandle As IntPtr)
       ' pop up the Get/Checkout dialog
       Dim settings As NewVDF.Vault.Forms.Settings.InteractiveAcquireFileSettings( _
           m_conn, parentWindowHandle, "Download files")
       settings.AddEntityToAcquire(fileIter)
       VDF.Vault.Forms.Library.AcquireFiles(settings)
End Sub
___________________________
Replies (25)
Message 2 of 26
machiel.veldkamp
I got this sub so far where I try to do stuff
Public Sub DownloadFiles(fileIters As ICollection(Of VDF.Vault.Currency.Entities.FileIteration))
	Dim Settings  = New Autodesk.DataManagement.Client.Framework.Vault.Settings.AcquireFilesSettings(mVltCon, False)
	Settings.LocalPath = New Autodesk.DataManagement.Client.Framework.Vault.Currency.FolderPathAbsolute("C:\TEMP")
	For Each fileIter As VDF.Vault.Currency.Entities.FileIteration In fileIters
		Settings.AddFileToAcquire(fileIter, VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download)
	Next
End Sub
I'm getting an error that Autodesk.DataManagement.Client.Framework.Vault.Currency.FolderPathAbsolute isn't defined.
The Vault API Says that this should be good though. Is this a bug where it's only working in C# but not in VBA?
Help! I don't get it!
Message 3 of 26
machiel.veldkamp
				Dim fname As String = dwgPath
				Dim file1 As Autodesk.Connectivity.WebServices.File()
				file1 = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths({fname })
				MessageBox.Show("1", "Title")
				If file1.Length <> 0 Then
					MessageBox.Show("Length = 0", "Title")
					Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
					oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(mVltCon, file1(0))
					'DownloadFiles(oFileIteration)
					If oFileIteration Is Nothing Then
						MsgBox("Error: Can't find the file")
						Exit Sub
					Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(mVltCon)
					MessageBox.Show("OK 1", "Title")
					'Going To Checkout And download
					oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download
					MessageBox.Show("OK 3", "Title")
					oSettings.OptionsRelationshipGathering.FileRelationshipSettings.IncludeChildren = False
					MessageBox.Show("OK 4", "Title")
					oSettings.OptionsRelationshipGathering.FileRelationshipSettings.RecurseChildren = True
					MessageBox.Show("OK 5", "Title")
					oSettings.OptionsRelationshipGathering.FileRelationshipSettings.VersionGatheringOption = VDF.Vault.Currency.VersionGatheringOption.Latest
					MessageBox.Show("OK 6", "Title")
					'oSettings.LocalPath = VDF.Vault.Currency.FolderPathAbsolute("C:\Relco\Vault\Designs\CUSTOMER WORK\VEOS\ZWEVEZELE\PROJECTS\18P22200000 REVAMP AIR INTAKE DRYER\18P22224700 DUCT HEATER TO DRYER") '
					Dim fldrPath As Autodesk.DataManagement.Client.Framework.Currency.FolderPathAbsolute = mVltCon.WorkingFoldersManager.GetWorkingFolder(oFileIteration)
					oSettings.LocalPath = fldrPath
					MessageBox.Show("OK 6.1", "Title")
					'mVltCon.WorkingFoldersManager.GetWorkingFolder(oFileIteration)
					MessageBox.Show("OK 6.2", "Title")
					oSettings.AddEntityToAcquire(oFileIteration)
					MessageBox.Show("OK 7", "Title")
					oSettings.LocalPath = mVltCon.WorkingFoldersManager.GetWorkingFolder(oFileIteration)'New VDF.Currency.FolderPathAbsolute("D:\Vault\Designs\") '
					mVltCon.FileManager.AcquireFiles(oSettings)
					MessageBox.Show("OK 8", "Title")
				MessageBox.Show("END 1", "Title")
				MissingFiles = MissingFiles + 1
Tried this: Still same issue. FolderPathAbsolute is not working
Message 4 of 26
could be a permissions issue on your machine - we had some issues with permissions and reading/writing to our local drives with some projects we are working on with the Vault SDK - might want to verify that you can read/write to your drive with whatever user account your running Inventor (your iLogic) under.
Message 5 of 26
machiel.veldkamp
image.pngThis is the error I'm getting while compiling.
I'm now trying to figure out what this means.
Message 6 of 26
bradeneuropeArthur
Hi, Add this:
	mVltCon.FileManager.AcquireFiles(Settings)
Next End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 26
machiel.veldkamp
Great news!
No such problems of permission... I hadn't added the reference to the framework yet!
You need all of these:
AddReference "Autodesk.DataManagement.Client.Framework.dll"
Message 8 of 26
machiel.veldkamp
Oh hi!
I didn't see your update just now.
I just pasted this and it gives me an error on compile:
Message 9 of 26
machiel.veldkamp
Posting the current Progress:
		VaultPartPath = Key.Replace("C:\Relco\Vault\", "$/")
		VaultDWGPath = dwgPath.Replace("C:\Relco\Vault\", "$/")
			CheckedOutFiles = CheckedOutFiles + 1
					Trace.WriteLine("Start test")
					Trace.WriteLine("FilleIteration")
	Next
	Trace.WriteLine("TEST")
	'Settings.LocalPath = New Autodesk.DataManagement.Client.Framework.Vault.Currency.FolderPathAbsolute("C:\TEMP")
	Settings.LocalPath = New VDF.Currency.FolderPathAbsolute("C:\TEMP") 'CHANGED THIS HERE.
	Next
	Trace.WriteLine("TEST END")
End Sub
 @bradeneuropeArthur The code outputs an error at DownloadFiles(oFileIteration)
Am I inputting the right values here you think?
edit: image.png
Message 10 of 26
bradeneuropeArthur
To test something:
msgbox (mVltCon.isconnected)
For Each fileIter As VDF.Vault.Currency.Entities.FileIteration In fileIters Settings.AddFileToAcquire(fileIter, VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download) mVltCon.FileManager.AcquireFiles(Settings) Next Trace.WriteLine("TEST END") End Sub
Please let me know the result of the connection!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 26
machiel.veldkamp
I can't get to that section yet since I'm not inputting oFileIteration correctly (yet)
However. I pasted the test just before I'm calling that :
Message 12 of 26
bradeneuropeArthur
Is it possible for you to implement this method, or don't you understand what to do with this piece of code.
Public Sub GetSelectedFiles(file As Autodesk.Connectivity.WebServices.File, m_connection As VDF.Vault.Currency.Connections.Connection, strTargetFolder As String)
        MsgBox(m_connection.IsConnected)
        Dim fileIter As VDF.Vault.Currency.Entities.FileIteration = m_connection.FileManager.GetFilesByIterationIds(New Long() {file.Id}).First().Value
        Dim targetDir As System.IO.DirectoryInfo = New System.IO.DirectoryInfo(strTargetFolder)
        If Not targetDir.Exists Then
            targetDir.Create()
        Dim downloadSettings As Autodesk.DataManagement.Client.Framework.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(m_connection)
        downloadSettings.LocalPath = New Autodesk.DataManagement.Client.Framework.Currency.FolderPathAbsolute(targetDir.FullName)
        downloadSettings.CreateMetaDataFile = True
        downloadSettings.AddFileToAcquire(fileIter, Autodesk.DataManagement.Client.Framework.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download)
        m_connection.FileManager.AcquireFiles(downloadSettings)
		end sub
Please let me know...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 26
machiel.veldkamp
The rules outputs an error:
It doesn't like the:
Dim fileIter As VDF.Vault.Currency.Entities.FileIteration = m_connection.FileManager.GetFilesByIterationIds(New Long() {File.Id}).First().Value
I tried calling it like this:
GetSelectedFiles(file1(0),mVltCon,"C:\TEMP")
I'm now pondering if this is legal:
file1 = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths({fname})
Where fname is the complete path + extension of the drawing or part.
Message 14 of 26
bradeneuropeArthur
Hi Machiel,
What version of the software are you using?
I am on 2018 Inventor and vault.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 26
machiel.veldkamp
Vault 2018 and Inventor 2018
Both pro
Message 16 of 26
machiel.veldkamp
Just to get it somewhere, here is the complete code I'm making.
It's quite big tho. Wall of text incoming:
Imports System.Text
Imports System.IO
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency'.Properties
'AddReference "Autodesk.DataManagement.Client.Framework.
'AddReference "Autodesk.DataManagement.Client.Framework.Forms.dll "
Sub Main()
	'''This tool was made by Machiel Veldkamp in 2018 and devoloped throughout 2019
	''' This tool works only on drawings that are in The Vault
	''' This tool works only if you have a connection to the "R:\" network Disk
	''' This tool only works when the BOM is enabled.
	''' All code should be commented. Email mveldkamp@relco.net For questions you might have
	''' The VersionChecker is not required for the tool. It's just a sort of updater.
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("Please run this rule from the ASSEMBLY file.", "iLogic")
		Exit Sub
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ VERSION CHECKER - - - START\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	VersionFolder = "R:\Drafting\09 iLOGIC VERSIONS"	'Make Folder Somewhere with Textfiles
	iLogicName = "IAM Bulk Drawing Tool" 				'Name of the Current
	Dim ExpectedVersion As Integer = 22
	oFile = VersionFolder & "\" & iLogicName & ".txt"
	'read the file
	oRead = System.IO.File.OpenText(oFile)
	Dim FileVersion As Integer = oRead.ReadToEnd()
	oRead.Close()
	If FileVersion = ExpectedVersion Then
		Trace.WriteLine(FileVersion & " Version is correct.")
	Else
		MessageBox.Show("Expected Version: " & FileVersion & vbNewLine & " Current Version on your PC: " & ExpectedVersion, "OLD VERSION. DO GET FROM VAULT")
		Exit Sub
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ VERSION CHECKER - - - END \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	Dim vaultaddin As ApplicationAddIn
	vaultaddin = ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}")
	Dim oSizePrinted As String 		'FALSE IS ORIGINALS 		| TRUE IS A3
	Dim oStopPrinting As Boolean 	'TRUE IS NO PRINTING 		| FALSE IS PRINTING
	Dim oStopExport As Boolean 		'TRUE IS NO EXPORT 			| FALSE IS EXPORT
	Dim oPrintLibrary As Boolean    'TRUE IS PRINT LIBRARY FILES| FALSE IS IGNORE LIBRARY AT ALL
	Dim ErrorMessage As String		'CREATE STRING WHERE ERROR MESSAGES CAN BE STORED
	ErrorMessage = "" 				'STARTS OUT EMPTY
	Dim xProduce As Integer			'Production amount
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ CUSTOM GUI \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	Dim ILOGIC_PRINT As Boolean			'true = print, false = ignore print
	Dim ILOGIC_EXPORT As Boolean		'true = export, false = ignore export
	Dim ILOGIC_PROD_AMOUNT As Integer	'Production amount. Can only be whole numbers
	Dim ILOGIC_LIBRARY As Boolean		'true = also process LIBRARIES, false = ignore LIBRARIES
	Dim ILOGIC_SORT As Boolean			'true = sort by A-Z, False = sort by BOM (per assembly)
	Dim ILOGIC_PRINT_PREF As String		'Can contain: "A4" or "A3"  or "ORIGINALS"
	Dim ILOGIC_WATERMARK As Boolean		'true = place watermark
	Dim ILOGIC_PROD_NO As String		'reserved for PROD#. Can be numbers and letters.
	Dim oModel As PartDocument
	Try
		ThisApplication.SilentOperation = False
		System.Threading.Thread.CurrentThread.Sleep(300)
		vaultaddin.Deactivate
		aFilePath = "C:\Relco\Vault\CAD Standards\Inventor\Design Data 2018\iLogic\BulkDrawingToolParam.ipt"
		oModel = ThisApplication.Documents.Open(aFilePath, False)
		auto = iLogicVb.Automation
		auto.RunRule(oModel, "Show Form") 'in the model there is a rule called "Show Form" that changes some parameters
		ILOGIC_PRINT = oModel.ComponentDefinition.Parameters("ILOGIC_PRINT").Value
		ILOGIC_EXPORT = oModel.ComponentDefinition.Parameters("ILOGIC_EXPORT").Value
		ILOGIC_PROD_AMOUNT = oModel.ComponentDefinition.Parameters("ILOGIC_PROD_AMOUNT").Value
		ILOGIC_LIBRARY = oModel.ComponentDefinition.Parameters("ILOGIC_LIBRARY").Value
		ILOGIC_SORT = oModel.ComponentDefinition.Parameters("ILOGIC_SORT").Value
		ILOGIC_PRINT_PREF = oModel.ComponentDefinition.Parameters("ILOGIC_PRINT_PREF").Value
		ILOGIC_WATERMARK = oModel.ComponentDefinition.Parameters("ILOGIC_WATERMARK").Value
		ILOGIC_PROD_NO = oModel.ComponentDefinition.Parameters("ILOGIC_PROD_NO").Value
		xProduce = ILOGIC_PROD_AMOUNT
		oPrintLibrary = ILOGIC_LIBRARY
		If ILOGIC_PRINT = True
			oStopPrinting = False
		Else
			oStopPrinting = True
		If ILOGIC_EXPORT = True
			oStopExport = False
		Else
			oStopExport = True
		oSizePrinted = ILOGIC_PRINT_PREF
		SortQuestion = ILOGIC_SORT
		GoTo GUI_Succes
		oModel.Close 'CLOSE MODEL
		vaultaddin.Activate
		Trace.WriteLine("Close GUI model")
	Catch
		Try
		Catch
		End Try
		Try
			vaultaddin.Activate
		Catch
		End Try
		MessageBox.Show("ERROR IN BulkDrawingToolParam.ipt MAYBE YOU CLICKED THE X INSTEAD OF 'DONE' HOWEVER. IT KINDA CRASHED", "IAM Bulk Drawing Tool")
		Trace.WriteLine("GUI FAILED")
		GoTo GUI_Failed
	End Try
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\  CUSTOM GUI - END \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	GUI_Failed :
	Trace.WriteLine("GUI FAILED - Continue")
	Dim oOptionList As New ArrayList
	oOptionList.Add("- PRINT ONLY")
	oOptionList.Add("- EXPORT ONLY")
	oOptionList.Add("- EXPORT + PRINT")
	oPrintExport = InputListBox("Prompt", oOptionList, oOptionList, Title := "Bulk Drawing Tool", ListName := "IAM Bulk Drawing Tool")
	Try
		xProduce = InputBox("ENTER A NUMBER", "How many times do you want to make this thing?", "1")
	Catch
		MessageBox.Show("You have to use just numbers. Comma's aren't allowed. Integers only :)" & vbNewLine & "Amount set to  1", "BULK DWG TOOL")
		xProduce = 1
	End Try
	If oPrintExport Is "- PRINT ONLY"
		oStopExport = True
		oSizePrinted = "A3" 'Due to conversion from the old to the new system for GUI, now the old method only handles A3
		SortQuestion = InputRadioBox("Sort to A-Z for printing?", "YES, Sort A-Z", "No, Leave as packets", SortQuestion, Title := "BULK DWG TOOL")
	Else If oPrintExport Is "- EXPORT ONLY"
	oStopExport = False
	Else
		oStopExport = False
	oPrintLibrary = InputRadioBox("Do you want to print Library and/ or Design Data Eu files? (manholes/ flanges/ etc)", "YES", "NO", oPrintLibrary, Title := "BULK DWG TOOL")
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ Continue from above\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	GUI_Succes :
	Trace.WriteLine("GUI SUCCES - CONTINUED")
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ GET PROJECT AND JOBNUMBER\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	Dim oModelName As String = ThisDoc.Document.FullFileName
	If ThisApplication.UserName = "MVE"
		If oModelName.Contains("Libraries") Then
			MessageBox.Show("This is a library part. Be sure to be logged in as Admin to export or print drawings. ", "BULK DWG TOOL")
	Else
			MessageBox.Show("Document is a library part. This is a forbidden action. ", "BULK DWG TOOL")
			vaultaddin.Activate
			Exit Sub
	Dim oComp As String = IO.Path.GetDirectoryName(oModelName)
	Dim oModelDir As String
	Dim oProjectNumber As String
	Dim oJobNumber As String
	'Detect Job and project number. If the drawing is located in a project folder this will be auto generated.
	If oComp.Contains("PROJECTS") Then
		'Get folder name of folder in "PROJECTS"
		Dim mysplit As Array = Split(oComp, "\")
		Dim i As Integer = (mysplit.Length - 1)
		Dim ii As Integer = i - 7 																'7 = naam van map in PROJECTS folder
		Dim Split1 As String() = oComp.Split("\")
		oModelDir = Split1(Split1.Length - ii)
		oProjectNumber = Left(oModelDir, 6) 													'MAKE  oProjectNumber
		Dim mysplit2 As Array = Split(oComp, "\")
		Dim i2 As Integer = (mysplit.Length - 1)
		Dim ii2 As Integer = i2 - 8 															'8 = naam van map in PROJECTS folder map
		Dim Split2 As String() = oComp.Split("\")
		oModelDir = Split2(Split2.Length - ii2)
		oJobNumber = Right(Left(oModelDir, 11), 5)												'MAKE  oJobNumber
		If ILOGIC_PROD_NO = ""
			QComment = "P-" & oProjectNumber & " J-" & oJobNumber & " PROD#______"				'QComment is the thing that is part of the Watermark on drawing.
		Else
			QComment = "P-" & oProjectNumber & " J-" & oJobNumber & " PROD#" & ILOGIC_PROD_NO	'QComment is the thing that is part of the Watermark on drawing.
	Else
		'Main assembly not located in "PROJECTS" folder. Manual input needed.
		QComment = InputBox("Non-project file detected. Please enter the WATERMARK COMMENT", "Bulk Drawing Tool", "P-19PXXX J-XXXXX PROD#000000 ")
		If QComment = " "
			QComment = ""
		Tools = InputBox("ASSY/DEBUG?", "BULK DRAWING TOOL", "Type:  " & ControlChars.Quote & "ASSY" & ControlChars.Quote & " to do just the top level drawing")
	'get user input
	RUsure = MessageBox.Show("READ THIS MESSAGE!! EVERY TIME!!!" & vbNewLine _
	& vbNewLine _
	& "PRINT =         " & Chr(9) & ILOGIC_PRINT & vbNewLine _
	& "EXPORT =        " & Chr(9) & ILOGIC_EXPORT & vbNewLine _
	& "________________" & vbNewLine _
	& vbNewLine _
	& "PRINT ON        " & Chr(9) & ILOGIC_PRINT_PREF & vbNewLine _
	& vbNewLine _
	& "PROJECT:        " & Chr(9) & oProjectNumber & vbNewLine _
	& "JOB:            " & Chr(9) & oJobNumber & vbNewLine _
	& "PROD #:         " & Chr(9) & ILOGIC_PROD_NO & vbNewLine _
	& vbNewLine _
	, "BULK DRAWING TOOL", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	If RUsure = vbNo Then
		Try
			vaultaddin.Activate
		Catch
			'Vault is already enabled
		End Try
		Exit Sub 'User wants to quit the Rule.
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ MAKE BOM\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ '
	Trace.WriteLine("MAKE BOM")
	Dim oTotalDict As New Dictionary(Of String, Integer)
	Dim oLOD As LevelOfDetailRepresentation
	Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	oAsmDoc.ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations("Master").Activate
	Dim oAssyDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	Trace.WriteLine("MAKE BOM2")
	'Dim oBOM As BOM = oAssyDef.BOM
	Trace.WriteLine("MAKE BOM3")
	oBOM = oAssyDef.BOM
	Trace.WriteLine("MAKE BOM4")
	oBOM.StructuredViewEnabled = True
	oBOM.StructuredViewFirstLevelOnly = False
	Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
	Dim oBOMRow As BOMRow
	Dim oCompDef As ComponentDefinition
	Trace.WriteLine("**************MAKE BOM ****************")
	For Each oBOMRow In oBOMView.BOMRows
		oCompDef = oBOMRow.ComponentDefinitions.Item(1)
		'oParentPartNumber = oCompDef.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		Trace.WriteLine("PARRENT: " & oParentPartNumber)
		Call SetRowProps(oCompDef, oBOMRow.TotalQuantity, oTotalDict, 1) 		' Set the oTotalDict Key and Value for this object
		If Not oBOMRow.ChildRows Is Nothing
			Call RecurseBOMRow(oBOMRow, oTotalDict, oBOMRow.TotalQuantity)
	Next
	Trace.WriteLine("****************SHOW BOM***********")
	Dim oCount As Integer = 0
	'Dim i As Integer
		' Trace.WriteLine(Key & " : " & oCount) 		' Before xProduce
		Number = oTotalDict.Values(i)
		oCount = Number * xProduce
		oTotalDict(Key) = oCount
		Trace.WriteLine(Key & " : " & oCount) 		' After xProduce
	Next
	'\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ SORT DICTIONARY \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
	'' If SortQuestion = True
	Trace.WriteLine("******************************************NEW DICTIONARY*START*********************************************")
	Dim OriginalKey As String
	Dim OriginalQTY As String
	Dim OriginalKeyLength As Integer
	Dim SplitLocation As Integer
	Dim SearchFor As String = "\"
	Dim FirstKey As String
	Dim SecondKey As String
	Dim SortArray As New ArrayList
		OriginalKey = oTotalDict.Keys(i)
		OriginalQTY = oTotalDict.Values(i)
		OriginalKeyLength = OriginalKey.Count
		SplitLocation = InStrRev(OriginalKey, SearchFor)
		FirstKey = Left(OriginalKey, SplitLocation)
		SecondKey = Right(OriginalKey, OriginalKeyLength - SplitLocation)
		SortArray.Add(SecondKey & "*" & FirstKey & "*" & OriginalQTY)
		Trace.WriteLine("FirstKey: " & FirstKey)
		Trace.WriteLine("SecondKey: " & SecondKey)
	Next
	SortArray.Sort 		'This sorts the reversed, stickied, string A-Z.
	oTotalDict.Clear	'delete all entries in oTotalDict and repopulate
	Dim oTotalDictKey As String
	Dim oTotalDictValue As Integer
	Trace.WriteLine("SORTER 94")
	For i = 0 To SortArray.Count - 1
		Firstdigit = Left(SortArray(i), 2)
		If Firstdigit = "94"
			'Trace.WriteLine(SortArray(i))
			Dim mysplit As Array = Split(SortArray(i), "*")
			oTotalDictKey = mysplit(1) & mysplit(0)
			'Trace.WriteLine(oTotalDictKey)
			oTotalDictValue = mysplit(2)
			'Trace.WriteLine(oTotalDictValue)
			oTotalDict.Add(oTotalDictKey, oTotalDictValue)
	Next
	Trace.WriteLine("SORTER 92")
		If Firstdigit = "92"
	Next
	Trace.WriteLine("SORTER 4")
		Firstdigit = Left(SortArray(i), 1)
		If Firstdigit = "4"
	Next
	Trace.WriteLine("SORTER 2")
		If Firstdigit = "2"
	Next
	Trace.WriteLine("SORTER 1")
		If Firstdigit = "1"
	Next
	Trace.WriteLine("SORTER THE REST")
		'Trace.WriteLine(Firstdigit)
		If Not Firstdigit = "1" And Not Firstdigit = "2" And Not Firstdigit = "4" And Not Firstdigit = "9"
	Next
	''End If
	Trace.WriteLine("******************************************NEW DICTIONARY*END*********************************************")
	'	For i = 0 To oTotalDict.Count - 1
	'		Key = oTotalDict.Keys(i)
	'		oCount = oTotalDict.Values(i)
	'	Next
	Trace.WriteLine("******************************************VAULT STATUS ITERATE**********************************************")
	Dim mVltCon As VDF.Vault.Currency.Connections.Connection
	mVltCon = VB.ConnectionManager.Instance.Connection
	If mVltCon Is Nothing Then
		MessageBox.Show("Not Logged In to Vault! - Login first and repeat executing this rule. (POTENTIONAL ADD-IN FAULURE)")
		Exit Sub
	Dim oStatusDict As New Dictionary(Of String, Integer)
	'''Lifecycle States
	'''Preliminary 					= LifecyclestateID: 24;	= oStatusDict: 1
	'''For Approval 				= LifecyclestateID: ;	= oStatusDict: 2
	'''Approved For Construction 	= LifecyclestateID: 31;	= oStatusDict: 3
	'''Obsolete 					= LifecyclestateID: ;	= oStatusDict: 4
	'''NotInVault					=						= oStatusDict:
	'''NotOnC						=						= oStatusDict:
	'''NoDrawingExists				=						= oStatusDict:
	Dim CheckedOutFiles As Integer = 0
	Dim MissingFiles As Integer = 0
		Dim DwgFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(mVltCon, wsFiels(0)) 		'DWG HERE
		Dim PartFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(mVltCon, wsFiels2(0)) 		'PART HERE (IPT/IAM)
					Trace.WriteLine("FilleIteration 1")
					'oFileIteration = GetFileIteration(fname, mVltCon)
					Trace.WriteLine("FilleIteration 1.5")
					Trace.WriteLine("FilleIteration 2")
	Next
	If MissingFiles > 0
		LastChance = MessageBox.Show("You are missing " & MissingFiles & " drawings from Vault. Do you want to CONTINUE?", "BULK DWG TOOL", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
		If LastChance = vbNo
			vaultaddin.Activate
			Exit Sub
	If CheckedOutFiles > 0
		LastChance = MessageBox.Show("You have " & CheckedOutFiles & " files checked out... Do you want to CONTINUE?", "BULK DWG TOOL", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
			vaultaddin.Activate
			Exit Sub
	Try
		Trace.WriteLine("VAULT DEACTIVATED")
		vaultaddin.Deactivate	'Disable the VAULT ADD-IN so Vault status and things won't interfere.
	Catch
		Try
			System.Threading.Thread.CurrentThread.Sleep(500)
		Catch
			MessageBox.Show("Couldn't deactivate Vault Add-in Try again later.", "Title")
			'Exit Sub
		End Try
	End Try
	'////////////////////////////////// TOP LEVEL DRAWING ////////////////////////////////////
	Trace.WriteLine("****************Doing top level Drawing (the main assembly)******************")
	ThisApplication.SilentOperation = True												'Disable all Inventor Pup-Ups
	iLogicVb.Automation.RulesOnEventsEnabled = False									'Disable all iLogic rules
	Dim oFilePath As String
	'MakeIndex(ThisDoc , oFilePath)
	oAsmDrawing = ThisDoc.ChangeExtension(".dwg")										'Takes the Assembly.iam and turns it into  Assembly.dwg
	Try
		oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)					'Opens Assembly.dwg
	Catch
		MessageBox.Show("There is no Assembly drawing. Rule quit", "Title")
		iLogicVb.RunRule("X - Reset Vault Addin")
		Exit Sub
	End Try
	Revision = GetRevision(oAsmDrawingDoc)
	oFilePath = oFindFolder(oModelName, QComment, Revision)								'FINDS THE EXPORT DESTINATION
	Trace.WriteLine("oFilepath:" & oFilePath)
	QuantityText = "| QTY = " & xProduce & "x"
	Trace.WriteLine("ASSY: Open DWG")
	oAsmDrawingName = Left(oAsmDrawingDoc.FullDocumentName, Len(oAsmDrawingDoc.FullDocumentName) - 3)
	If ILOGIC_WATERMARK = True
		Trace.WriteLine("ASSY: Watermark")
		WaterMark(oAsmDrawingDoc, QuantityText, QComment)
		Trace.WriteLine("WATERMARK - COMPLETED")
	Trace.WriteLine("ASSY: Export")
	Export_PDF_DWG(oAsmDrawingDoc, oStopExport, oFilePath, Revision)
	Trace.WriteLine("Doing DrawingList starting thing now:")
	DrawingList(oAsmDrawingDoc, xProduce, QComment, False, oFilePath, oStopPrinting, oStopExport, Revision)   'Starts making the DrawingList. Boolean Here is status for the Sub.
	Trace.WriteLine("ASSY: Print")
	Print(oAsmDrawingDoc, oSizePrinted, oStopPrinting)
	Trace.WriteLine("ASSY: Close")
	oAsmDrawingDoc.Close(True)
	'////////////////////////////END TOP DRAWING ////////////////////////////////////////
	If Tools = "ASSY"
		vaultaddin.Activate
		Exit Sub
	Trace.WriteLine("Completed Assembly Drawing. Now openening and processing the underlying drawings.")
	'////////////////////////////////////////LOOP DRAWINGS/ UPDATE / EXPORT ////////////////////////////////////////
	Dim oDrawDoc As DrawingDocument
		dwgPathName = Left(key, Len(Key) - 3) & "dwg" 									'Make a path and replace the last 3 symbols to dwg. (2-123456.iam to 2-123456.dwg)
		If (System.IO.File.Exists(dwgPathName)) Then									'Look for DWG files of the models in the BOM
			oDrawDoc = ThisApplication.Documents.Open(dwgPathName, True)				'Open the dwg.
			Trace.WriteLine("DrawingList: " & Key)
			Revision = GetRevision(oDrawDoc)										'Get revision from Function GetRevision()
			DrawingList(oDrawDoc, oTotalDict.Values(i), QComment, True, oFilePath, oStopPrinting, oStopExport, Revision) 'MAKE DRAWINLIST ROW.
			Trace.WriteLine("i=" & i & " \\ Remaining: " & oTotalDict.Count)
			If oDrawDoc.FullFileName.Contains("Libraries") Then						'SKIP Library file
				If oPrintLibrary = True												'If Printing is allowed continue.
					If Tools = "DEBUG" Then
						'skip for speed
					Else
						Export_PDF_DWG(oDrawDoc, oStopExport, oFilePath, Revision)
						Print(oDrawDoc, oSizePrinted, oStopPrinting)				'Print the Library file
				oDrawDoc.Close(True)												'Close the LIB file
				oTotalDict.Remove(Key)' Remove object from oTotalDict.
				i = i - 1
			Else If Not oDrawDoc.FullFileName.Contains("Libraries") Then			'Normal file:
			Try																	'Try loop. Safer way to do it.
				QuantityText = "| QTY = " & oTotalDict(Key) & "x" 				'Make text for comment on drawing
					WaterMark(oDrawDoc, QuantityText, QComment)					'Place Watermark on drawing
					'skip for speed
				Else
					Export_PDF_DWG(oDrawDoc, oStopExport, oFilePath, Revision)	'Export Drawing
					Print(oDrawDoc, oSizePrinted, oStopPrinting)				'Print Drawing
			Catch
				ErrorMessage = ErrorMessage & "| " & Key & vbNewLine			'Make error message if failed.
			End Try
			i = i - 1
		Else
			'If the model has no drawing of the same path and name - do nothing
			'MessageBox.Show("This model has no drawing!" & oRefDoc.FullDocumentName, "Title"
		If i = oTotalDict.Count - 1
			Trace.WriteLine("********************LAST LEG*************************")
			Exit For
	Next
	Trace.WriteLine("*********************************just finnished the loop")
	'//////////////////////////// END OF TOTALDICTLOOP //////////////////////
	DrawingList(oAsmDrawingDoc, "END_OF_DRAWINGS", QComment, False, oFilePath, oStopPrinting, oStopExport, "") 'At this stage. The rule will print the TXT and then Delete the Temp file
		If Key.Contains("PROJECTS") Then
			DrawingList(oAsmDrawingDoc, "MISSING_DRAWINGS", Key, False, oFilePath, oStopPrinting, oStopExport, "") 'At this stage. The rule will print the TXT and then Delete the Temp file
	Next
	If ErrorMessage = ""
		'No errors. Nice
	Else
		ErrorMessage = "The following drawings may nog have been printed/exported correctly: " & vbNewLine & "| " & Key & vbNewLine
		MessageBox.Show(ErrorMessage, "BULK DWG TOOL")
	Trace.WriteLine("NOTE: LAST ACTION")
	DrawingList(oAsmDrawingDoc, "STOP", QComment, False, oFilePath, oStopPrinting, oStopExport, "") 'At this stage. The rule will print the TXT and then Delete the Temp file
	'//////////////////////////////////////// Windows Voice ////////////////////////////////////////
	Dim objSPVoice, colVoices
	objSPVoice = CreateObject("SAPI.SpVoice")
	objSPVoice.Speak("attention: rule finished")
	'- - - - - - - - - -  Windows Voice - - END  - - - - - - - -
	If oStopExport = False
		OpenFolder = MessageBox.Show("Would you open the folder? Files saved in:       " & oFilePath, "BULK DWG TOOL", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
		If OpenFolder = vbYes Then
			Dim Proc As String = "Explorer.exe"
			Dim Args As String = ControlChars.Quote & oFilePath & ControlChars.Quote
			Process.Start(Proc, Args)
	Else
		MessageBox.Show("FILES PRINTED. CHECK PRINTER/PLOTTER", "Title")
	vaultaddin.Activate
	ThisApplication.SilentOperation = False												'Disable all Inventor Pup-Ups
	iLogicVb.Automation.RulesOnEventsEnabled = True
End Sub 'END OF MAIN()
Sub WaterMark(oDrawDoc As DrawingDocument, QuantityText As String, QComment As String)
	'Trace.WriteLine("WATERMARK - BEGIN")
	Dim oTG As TransientGeometry
	oTG = ThisApplication.TransientGeometry
	oDrafstman = ThisApplication.UserName
	Dim oSheet As Sheet
	Dim s As Sheet
	oSheet = oDrawDoc.ActiveSheet
	Dim oGeneralNote As GeneralNote
	Dim oGeneralNotes As GeneralNotes
	Dim oColor As Color
	oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
	sFormattedText = "<StyleOverride FontSize='0,32' Bold='True'>" + " prnt by: " & oDrafstman & "| |" & QComment & QuantityText + "</StyleOverride>"
	'Trace.WriteLine("WATERMARK - START LOOP")
	For Each s In oDrawDoc.Sheets										'BROWSE ALL SHEETS
		If s.Size = "9993" Or s.Size = "9994" Or s.Size = "9995" Then 							'For A1, A0, A2
			s.Activate													'ACTIVATE CURRENT SHEET
			For Each oSymbol As SketchedSymbol In s.SketchedSymbols
				If oSymbol.Name = "(EU) DRAWING STATE" Then				'FIND DRAWING STATE BLOCK
					Dim oPoint As Point2d = oSymbol.Position			'DECLARE POINT2D
					oPoint.X = s.Width - 9								'NEW X COORD
					oPoint.Y = 9										'NEW Y COORD
					oSymbol.Position = oPoint							'UPDATE SYMBOL WITH NEW POSITION
			Next
		Else															'for A4, A3, A2
			s.Activate													'ACTIVATE SHEET
				If oSymbol.Name = "(EU) DRAWING STATE" Then				'FIND SYMBOL
					Dim oPoint As Point2d = oSymbol.Position			'DECLARE NEW POINT
					oPoint.Y = 7.3										'NEW Y COORD
					oSymbol.Position = oPoint							'UPDATE POSITION WITH NEW POINT
			Next
	Next
	'Trace.WriteLine("WATERMARK - LOOP 2")
		s.Activate
		oGennotes = s.DrawingNotes.GeneralNotes
		If s.Size = "9993" 'A0
			If s.Orientation = "10242"
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(102, 10.2), sFormattedText)	'LANDSCAPE
			Else
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(68, 10.2), sFormattedText)	'PORTRAIT
		If s.Size = "9994" 'A1
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(67.5, 10.2), sFormattedText)	'LANDSCAPE
			Else
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(42.5, 10.2), sFormattedText)	'PORTRAIT
		If s.Size = "9995" 'A2
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(50 - 6 - 0.8, 8.2), sFormattedText)	'LANDSCAPE
			Else
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(30 - 3 - 0.8, 8.2), sFormattedText)	'PORTRAIT
		If s.Size = "9996" 'A3
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(30 - 3 - 0.8, 8.2), sFormattedText)	'LANDSCAPE
			Else
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(20 - 5 - 0.8, 8.2), sFormattedText)	'PORTRAIT
		If s.Size = "9997" 'A4
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(20 - 5 - 0.8, 8.2), sFormattedText)	'LANDSCAPE
			Else
				oGeneralNote = oGenNotes.AddFitted(oTG.CreatePoint2d(15 - 9 - 0.8, 8.2), sFormattedText)	'PORTRAIT
		oGeneralNote.Color = oColor
	Next
	'Trace.WriteLine("WATERMARK - END")
End Sub 'END OF WATERMARK()
Sub RecurseBOMRow(oBOMRow As BOMRow, oTotalDict As Dictionary(Of String, Integer), newParentQTY As Integer)
	Trace.WriteLine("START of RecurseBOMRor for: " & oBOMRow.ComponentDefinitions.Item(1).Document.FullDocumentName & "QTY = " & oBOMRow.TotalQuantity & " Parent = " & newParentQTY)
	ParentQTY = oBOMRow.TotalQuantity 													' Set a new ParentQTY amount. When first encountered newParentQTY is 1
	For Each oBOMRow In oBOMRow.ChildRows
		oParent = oBOMRow.Parent
		'oParentPartNumber = oParent.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		Call SetRowProps(oCompDef, oBOMRow.TotalQuantity, oTotalDict, newParentQTY) 	' Set the oTotalDict Key and Value for this object with the newParent QTY(should be 1 at first run.)
		If Not oBOMRow.ChildRows Is Nothing 											' Ooooh. Assembly.
			ParentQTY = oBOMRow.TotalQuantity 											'Now we;re looking in the row of the assembly in the assembly. The current value is just the value in that parent. We still need multiplication
			newnewParentQty = ParentQTY * newParentQTY 									'We're a couple of layers in now. We still hold newParentQTY from the current Parent. Parent QTY is th current value and newnewParent is the multiplication of those 2
			Trace.WriteLine("DIGGIN DEEPER --: " & oBOMRow.ComponentDefinitions.Item(1).Document.FullDocumentName & " QTY = " & oBOMRow.TotalQuantity & " Parent = " & ParentQTY & " newParent = " & newParentQTY & " newnewParent = " & newnewParentQty)
			Call RecurseBOMRow(oBOMRow, oTotalDict, newnewParentQty)
	Next
End Sub
Sub SetRowProps(oCompDef As ComponentDefinition, QTY As Integer, oTotalDict As Dictionary(Of String, Integer), ParentQTY As Integer)
	Trace.WriteLine("START SetRowProps for " & oCompDef.Document.FullDocumentName & " QTY is: " & QTY & " Parent = " & ParentQTY)
	Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
	Dim CompFileNameOnly As String
	Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
	CompFileNameOnly = CompFullDocumentName.Substring(index + 1)
	If oTotalDict.ContainsKey(CompFullDocumentName) = True Then
		KeyValue = oTotalDict(CompFullDocumentName)
		Trace.WriteLine("EXISTING KEY. CURRENT QTY = " & KeyValue)
		QTY = QTY * ParentQTY
		Trace.WriteLine("ADDING: " & QTY)
		oTotalDict(CompFullDocumentName) = QTY + KeyValue
		Trace.WriteLine("NEW QTY = " & oTotalDict(CompFullDocumentName))
	Else
		oTotalDict(CompFullDocumentName) = QTY * ParentQTY
		Trace.WriteLine("NEW KEY. QTY = " & oTotalDict(CompFullDocumentName))
End Sub
Sub Export_PDF_DWG(oDrawDoc As DrawingDocument, oStopExport As Boolean, oFilePath As String, Revision As String)
	If oStopExport = True
		Exit Sub
	Trace.WriteLine(oFilePath)
	oFileName = oDrawDoc.DisplayName 'without extension
	oDuctName = oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("description").Value
	Dim oCleanString As String = System.Text.RegularExpressions.Regex.Replace(oDuctName, "[^A-Za-z0-9_ .-]", "_")  	'REPLACE FORBIDDEN CHARS BY "_" --> ([A-Za-z0-9_ -] ARE NOT (^) FORBIDDEN.
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 				'LOAD PDF ADD-IN
	Dim oDWGAddIn As TranslatorAddIn
	oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")				'LOAD DWG ADD-IN
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMediumPDF = ThisApplication.TransientObjects.CreateDataMedium
	oDataMediumDWG = ThisApplication.TransientObjects.CreateDataMedium'.FileName(False) 'without extension
	' - - - - - - - - - - - - - - - - - PDF Setup - - - - - - - - - - - - - - - - - -
	oOptions.Value("All_Color_AS_Black") = 0 '0 = color // 1 = black
	oOptions.Value("Remove_Line_Weights") = 0 'boolean
	oOptions.Value("Vector_Resolution") = 700
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'- - - - - - - - - - - - - - - - - -DWG SETUP - - - - - - - - - - - - - - - - - -
	If oDWGAddIn.HasSaveCopyAsOptions(oDrawDoc, oContext, oOptions) Then 									'Check whether the translator has 'SaveCopyAs' options
		Dim strIniFile As String
		strIniFile = "C:\Relco\Vault\CAD Standards\Inventor\Design Data 2018\iLogic\DWG_MODEL_2018.ini"		'INI FILE IS VOOR MODELSPACE
		oOptions.Value("Export_Acad_IniFile") = strIniFile													'Create the name-value that specifies the ini file to use.
	' - - - - - - - - - - - get  target folder path- - - - - - - - - - - - -
	If Not System.IO.Directory.Exists(oFilePath) Then
		System.IO.Directory.CreateDirectory(oFilePath)
	' - - - - - - - - - - - - Set the destination file name - - - - - - - - - - - -
	Dim fileName As String
	fileName = oDrawDoc.DisplayName & " - " & oCleanString & " - REV " & Revision
	oDataMediumDWG.FileName = oFilePath & "\" & fileName & ".dwg"
	oDataMediumPDF.FileName = oFilePath & "\" & fileName & ".pdf"
	'	Trace.WriteLine(fileName & "|| " & Len(fileName))
	'	Trace.WriteLine(oFilePath & "|| " & Len(oFilePath))
	CountString = Len(fileName) + Len(oFilePath) + 1
	If CountString > 255
		MessageBox.Show("WARNING: CANNOT SAVE FILE> FILENAME TOO LONG", "Title")
		Exit Sub
	' - - - - - - - - - - - - - Create PDF + DWG - - - - - - - - - - - - - - -
	Trace.WriteLine("Make PDF now:")
	oPDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMediumPDF)
	Trace.WriteLine("Make DWG now:")
	oDWGAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMediumDWG)
End Sub 'END OF EXPORT()
Sub Print(oDrawDoc, oSizePrinted, oStopPrinting)
	If oStopPrinting = True
		Exit Sub
	Dim Printer = "RICOH MP-C3004 - beneden"
	If ThisApplication.UserName = "JBE" Or ThisApplication.UserName = "JVV"
		Printer = "Ricoh MP-C3004 Boven"
	Dim Plotter = "HP DesignJet T930 PS HPGL2"
	Dim oPrintMgr As PrintManager
	oPrintMgr = oDrawDoc.PrintManager
	oPrintMgr.ColorMode = 13314
	If oSizePrinted = "A4"										'A3 ALWAYS AND EVER
		For Each s In oDrawDoc.Sheets				 			'checks each sheet
			s.Activate											'Activate Sheet
			oPrintMgr.Printer = Printer
			oPrintMgr.PaperSize = "14341"
			oPrintMgr.ScaleMode = 13826 						'kPrintBestFitScale = best scale fit
			oPrintMgr.PrintRange = 14081 						'kPrintCurrentSheet = current sheet
				oPrintMgr.Orientation = 13570	'LANDSCAPE
			Else
				oPrintMgr.Orientation = 13569	'PORTRAIT
			oPrintMgr.SubmitPrint
		Next
	Else If oSizePrinted = "A3"
		oPrintMgr.PaperSize = "14340"
		Else
	Next
	Else If oSizePrinted = "ORIGINALS"
			oPrintMgr.Printer = Plotter
			oPrintMgr.PaperSize = "14357"
			Else
			oPrintMgr.PaperSize = "14359"
			Else
			oPrintMgr.PaperSize = "14339"
			Else
			Else
			Else
	Next
End Sub 'END OF PRINT()
Function oFindFolder(oDrawDoc, QComment, Revision)', oFilePath)
	''' THIS CODE IS ALTERED SO IT MAY WRITE ALL DRAWINGS TO "R:\Drafting\10 TEKENINGEN\"
	''' Previously the location was 						"R:\Orders\20" & ProjYear & "\Projecten\" & ProjectChooser & "\Tekeningen Engineering\2D Tekeningen"
	Dim oComp As String = IO.Path.GetDirectoryName(oDrawDoc)
	'Check if subfolder "PROJECTS" exists in file path
	Dim oAssyName As String
		Dim ii As Integer = i - 7 '7=naam van map in PROJECTS folder 4=naam van company in CUSTOMER WORK folder
		Location = "PROJECTS"
	Else If oComp.Contains("DESIGN DATA EU") Then
	Location = "DESIGN DATA EU"
	Dim ii As Integer = i - 3 '7=naam van map in PROJECTS folder 4=naam van company in CUSTOMER WORK folder
	Else
		oModelDir = "CUSTOM"
		Location = "CUSTOM"
	oDuctName = iProperties.Value("Project", "Description")'oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("description").Value
	Dim oCleanString As String = System.Text.RegularExpressions.Regex.Replace(oDuctName, "[^A-Za-z0-9_ .-]", "_")  'Vervang verboden tekens in bestandsnaam door "_" --> ([A-Za-z0-9_ -] zijn NIET (^) verboden.
	'Add Projects below
	Select Case oModelDir
		'Case "Vault Folder Name"
		'ProjectChooser = "Folder name on G:\ or R:\"
		Case "CUSTOM"
			ProjectChooser = "CUSTOM"
		Case "DESIGN DATA EU"
			ProjectChooser = "DESIGN DATA EU"
		Case "LIBRARIES"
			ProjectChooser = "LIBRARY"
			'''************** COPY THESE TWO LINES TO ADD A NEW PROJECT ****************
		Case "" 									'''Vault FolderName
			ProjectChooser = "19PX00 NAME"			'''"Name on R:/"
		Case Else	'if no other project is found. It gets the status "Projectless"
			ProjectChooser = "Projectless"
	End Select
	Try 																'Get FolderName for current file
		FolderNameLoc = Mid(ThisDoc.Path, InStrRev(ThisDoc.Path, "\"))
	Catch
		MessageBox.Show("error determining the folder location", "Error in BULK DWG TOOL", MessageBoxButtons.OK, MessageBoxIcon.Stop)
		Exit Function
	End Try
	Try
		ProjYear = Left(ProjectChooser, 2) ' Read the ProjectYear (valid from 2000 - 2099)
	Catch
		MessageBox.Show("ERR: 2368*%& Wrong Project. Ask Machiel Veldkamp to fix the Code. Email a screenshot to mveldkamp@relco.net with this error", "ERROR #2018 BULK DWG TOOL")
	End Try
	If ProjectChooser = "DESIGN DATA EU"
		oFindFolder = "R:\Drafting\00 DESIGN DATA EU" & FolderNameLoc & "\" & QComment & oCleanString & " " & ThisDoc.FileName & "-REV " & Revision ' & " - " & Now.ToString("yyyy/MM/dd")
	Else If ProjectChooser = "LIBRARY"
	oFindFolder = "R:\Drafting\00 DESIGN DATA EU" & ProjectChooser & "\" & FolderNameLoc & "\" & QComment & oCleanString & " " & ThisDoc.FileName & "-REV " & Revision ' & " - " & Now.ToString("yyyy/MM/dd")
	Else If ProjectChooser = "Projectless"
	MessageBox.Show("This is not the right thing. This tool is meant for Project files and possibly DATA DESIGN Files. Either you are doing something weird or the project isn't added yet. In any case: Notify Machiel Veldkamp. ", "Title")
	Else
		'oFindFolder = "\\datasrv\Data\RELCO_BV\Orders\20" & ProjYear & "\Projecten\" & ProjectChooser & "\Tekeningen Engineering\2D Tekeningen" & FolderNameLoc & "\" & QComment & " " & ThisDoc.FileName & "-REV " & Revision & " " & oCleanString & " - " & Now.ToString("yyyy/MM/dd")
		'oFindFolder = "R:\Orders\20" & ProjYear & "\Projecten\" & ProjectChooser & "\Tekeningen Engineering\2D Tekeningen" & FolderNameLoc & "\" & QComment & " " & ThisDoc.FileName & "-REV " & Revision & " " & oCleanString & " - " & Now.ToString("yyyy/MM/dd")
		oFindFolder = "R:\Drafting\10 TEKENINGEN\" & ProjectChooser & FolderNameLoc & "\" & QComment & " " & ThisDoc.FileName & "-REV " & Revision & " " & oCleanString & " - " & Now.ToString("yyyy/MM/dd")
End Function 'END OF oFINDFOLDER()
Function GetRevision(oDrawDoc As DrawingDocument)
	'Trace.WriteLine("GetRevision called.")
	Try
		oDrawDoc.Sheets.Item(1).Activate
	Catch
		'No fish :(
	End Try
	Try
		' Set a reference to the first revision table on the active sheet.
		' This assumes that a revision table is on the active sheet.
		Dim oRevTable As RevisionTable
		oRevTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
		GetRevision = oRevTable.RevisionTableRows.Item(oRevTable.RevisionTableRows.Count).Item(1).Text
		'Trace.WriteLine("Revision is: " & GetRevision)
	Catch
		'No revision block
		GetRevision = 99
		Trace.WriteLine("GetRevision failed. No rev block?.")
		'MessageBox.Show("Revision failed", "Title")
	End Try
End Function
Sub DrawingList(oDrawDoc As DrawingDocument, QTY As String, QComment As String, oBool As Boolean, oFilePath As String, oStopPrinting As Boolean, oStopExport As Boolean, oCurrRev As String)
	Trace.WriteLine("CALLING DRAWINGLIST")
	Dim oFile As String
	If oStopExport = True 	'No export. If there is no export, change folders.
		oFile = "C:\Relco\DrawingList.txt"
		Trace.WriteLine("DrawingList: PRINT")
	Else 					'Yes export
		oFile = oFilePath & "\DrawingList.txt"
		Trace.WriteLine("DrawingList: EXPORT")
	Dim oFileExists As Boolean = System.IO.File.Exists(oFile)
	Trace.WriteLine(oFileExists)
	'	Try
	'		oFileName = oDrawDoc.FullDocumentName
	'		WhereUsed = oDrawDoc.FindWhereUsed(oFileName)
	'		ParentPartnumber = WhereUsed.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	'		Trace.WriteLine(oFileName & " - PARENT IS: " & ParentPartnumber)
	'	Catch
	'		Trace.WriteLine("Fail for the PARENT.....")
	'	End Try
	'Dim oCurrRev As String
	Dim Fileout As Object
	Dim oPartNumber As String
	Dim oFolderName As String
	Dim AssyPath As String
	Dim oStatus As String
	oFolderName = Mid(oFilePath, InStrRev(oFilePath, "\") + 1)
	AssyPath = Mid(ThisDoc.Path, InStrRev(ThisDoc.Path, "\"))
	Dim fso As Object
	fso = CreateObject("Scripting.FileSystemObject")
	Try
		oPartNumber = oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	Catch
		Trace.WriteLine("DrawingList Failed: oPartnumber")
	End Try
	Try
		oDescription = oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("description").Value
	Catch
		Trace.WriteLine("DrawingList Failed: oDescription")
	End Try
	Try
		oStatus = oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("User Status").Value
		If oStatus = "PRELIMINARY"
			oStatus = "PRE"
		Else If oStatus = "FOR APPROVAL"
		oStatus = "FAP"
		Else If oStatus = "APPROVED FOR CONSTRUCTION"
		oStatus = "AFC"
	Catch
		'Cant get status. Assume Preliminary?
		If oStatus = ""
			oStatus = "   "
	End Try
	If oBool = False And oFileExists = False ' IF NEW FILE.
		Trace.WriteLine("DrawingList: initialising")
		Fileout = fso.CreateTextFile(oFile, True)
		'Trace.WriteLine("DrawingList: Generating Textfile")
		Fileout.WriteLine("DRAWINGLIST: " & Chr(9) & QComment)
		Fileout.WriteLine("TOP DRAWING: " & Chr(9) & oPartNumber & " - " & oDescription & "- REV" & oCurrRev)
		Fileout.WriteLine("FOLDER: " & Chr(9) & Chr(9) & oFolderName)
		Try
			Fileout.WriteLine("STATUS: " & Chr(9) & Chr(9) & oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("User Status").Value)
		Catch
			Trace.WriteLine("DRAWINGLIST: FAILED TO GET STATUS")
		End Try
		Fileout.WriteLine("PRE = PRELIMINARY")
		Fileout.WriteLine("FAP = FOR APPROVAL")
		Fileout.WriteLine("AFC = APPROVED FOR CONSTRUCTION")
		Fileout.WriteLine("_________________________________")
		Fileout.WriteLine("")
		Fileout.WriteLine("NUMBER" & Chr(9) & "| QTY" & Chr(9) & " | REV" & Chr(9) & " | STATUS" & Chr(9) & " | DESCRIPTION")
		Fileout.WriteLine(oPartNumber & " | " & QTY & "x" & Chr(9) & " | " & "REV" & oCurrRev & Chr(9) & " | " & oStatus & Chr(9) & " | " & oDescription)
		Trace.WriteLine("DrawingList: Closed Textfile")
		Fileout.close()
	Else If oBool = True And oFileExists = True ''' PARTS AND ASSEMBLY LINES
	Trace.WriteLine("DrawingList: Write line")
	Fileout = fso.OpenTextFile(oFile, 8)
	Fileout.close()
	Else If oBool = False And QTY = "END_OF_DRAWINGS"
	Trace.WriteLine("DrawingList: END OF DRAWINGS")
	Fileout.WriteLine(" ")
	Fileout.WriteLine("THE FOLLOWING PROJECTFILES HAVE NO DRAWING: ")
	Fileout.close()
	Else If oBool = False And oFileExists = True And QTY = "MISSING_DRAWINGS"
	Trace.WriteLine("DrawingList: MISSING DRAWINGS")
	Trace.WriteLine("QComment: " & QComment)
	Dim oMissing As String = Mid(QComment, InStrRev(QComment, "\") + 1)
	Trace.WriteLine(oMissing & " HAS NO DRAWING!")
	Fileout.WriteLine(oMissing)' & oMissing & " has no drawing.")
	Fileout.close()
	Else If oBool = False And oFileExists = True And QTY = "STOP"
	Trace.WriteLine("STOP: print drawinglist")
	Fileout.WriteLine("____________________")
	Fileout.WriteLine("END OF DRAWINGLIST")
	Fileout.close()
	If oStopPrinting = False
		Trace.WriteLine("PRINT DRAWINGLIST")
		Try
			Shell("notepad.exe /p " + oFile)
		Catch
			MessageBox.Show("FAILED TO PRINT DRAWINGLIST. TRYING AGAIN BUT THEN DIFFERENT", "Title")
			Shell("notepad.exe /p " & oFile)
		End Try
		Trace.WriteLine("Kill File")
		Kill(oFile)
	Trace.WriteLine("ENDING DRAWINGLIST")
End Sub
	MsgBox (mVltCon.isconnected)
	Next
End Sub
'Private Function GetFileIteration(nameOfFile As String, connection As VDF.Vault.Currency.Connections.Connection) As VDF.Vault.Currency.Entities.FileIteration
'		Trace.WriteLine("GetFileIteration")
'        Dim conditions As ACW.SrchCond()
'        ReDim conditions(0)
'        Dim lCode As Long = 1
'        Dim Defs As ACW.PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
'        Dim Prop As ACW.PropDef = Nothing
'        For Each def As ACW.PropDef In Defs
'            If def.DispName = "File Name" Then
'                Prop = def
'            End If
'        Next def
'        'store path in new string
'        Dim pathname As String = nameOfFile.Substring(0, nameOfFile.LastIndexOf("\") + 1)
'        Trace.WriteLine(pathname)
'        'remove path from nameOfFile
'        Dim filename As String = nameOfFile.Substring(nameOfFile.LastIndexOf("\") + 1, nameOfFile.Length - pathname.Length)
'        Trace.WriteLine(filename)
'        'convert local path string to vault format
'        Dim VaultPath As String = pathname.Substring(0, pathname.Length - 1)
'        VaultPath = VaultPath.Replace("C:\Relco\Vault\", "$/")
'        'flip the slashes
'        VaultPath = VaultPath.Replace("\", "/")
'        Debug.WriteLine(VaultPath)
'        Dim DocService As Autodesk.Connectivity.WebServices.DocumentService
'        Dim myFolder As Folder
'        Dim myFolderId As Long
'		Trace.WriteLine("GetFileIteration 0.5 ")
'        Try
'			DocService = New Autodesk.Connectivity.WebServices.DocumentService()
'			myFolder = DocService.GetFolderByPath(VaultPath)
'			myFolderId = myFolder.Id
'        Catch ex As Exception
'            Trace.WriteLine(ex.Message)
'        End Try
'        Trace.WriteLine(myFolderId)
'        Dim myFolderIds(0) As Long
'        myFolderIds(0) = myFolderId
'        Dim searchCondition As ACW.SrchCond = New ACW.SrchCond()
'        searchCondition.PropDefId = Prop.Id
'        searchCondition.PropTyp = ACW.PropertySearchType.SingleProperty
'        searchCondition.SrchOper = lCode
'        'searchCondition.SrchTxt = nameOfFile 'nameofFile includes path
'        searchCondition.SrchTxt = filename 'filename does not include path
'        conditions(0) = searchCondition
'        'search for files
'        Dim FileList As List(Of Autodesk.Connectivity.WebServices.File) = New List(Of Autodesk.Connectivity.WebServices.File)()
'        Dim sBookmark As String = String.Empty
'        Dim Status As ACW.SrchStatus = Nothing
'        While (Status Is Nothing OrElse FileList.Count < Status.TotalHits)
'            Dim files As Autodesk.Connectivity.WebServices.File() = connection.WebServiceManager.DocumentService. _
'                        FindFilesBySearchConditions(conditions, Nothing, myFolderIds, True, True, sBookmark, Status)
'            If (Not files Is Nothing) Then
'                FileList.AddRange(files)
'            End If
'        End While
'        Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, FileList(0))
'        Return oFileIteration
'		Trace.WriteLine("GetFileIteration END")
'    End Function
Public Sub GetSelectedFiles(File As Autodesk.Connectivity.WebServices.File, m_connection As VDF.Vault.Currency.Connections.Connection, strTargetFolder As String)
		MessageBox.Show("Message", "Title")
            targetDir.Create()
End Sub
Message 17 of 26
bradeneuropeArthur
I will take a look....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 26
machiel.veldkamp
Awesome.
Thanks a bunch already. This whole Vault thing is super complicated for me still.
Message 19 of 26
bradeneuropeArthur
Could you please write step by step what you want to do.
The code is a little to complex to test here with all the different paths.
Seems that te code can be reduced and simplified, if I know what you want...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 26
machiel.veldkamp
Hi @bradeneuropeArthur
The complete code does multiple thing but I want to have a 'pre check' where I check all Parts/Assemblies and Drawings to the Vault.
I want to
- Make sure all files are checked in. Notify User if >1 files are checked out.
- Notify user if some drawings are not checked in yet.
- Make sure all files on 'C:/' are the latest. Notify User if drawings are old and present the option to download new ones or ignore that the files are old and continue anyway.
I was planning to do it all in the first loop where I do:
'Look in the vault and do all the things
Next
oTotalDict holds all BOM parts and assemblies with the QTY.
