Access to Vault file properties through Inventor
I'm trying to write a program that will allow me to read an iProperty value of an Inventor file in Vault.
I can't get past the first hurdle of establishing the connection. The code below produces the following errors:
Error on Line 6 : Type 'VDF.Vault.Currency.Connections.Connection' is not defined.
Error on Line 9 : 'Connectivity' is not declared. It may be inaccessible due to its protection level.
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports Autodesk.Connectivity.WebServices
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports ACW = Autodesk.Connectivity.WebServices
Dim myConnection As VDF.Vault.Currency.Connections.Connection = Nothing
' Get the Vault connection from
' the Inventor Vault log in
myConnection = Connectivity.Application.VaultBase.ConnectionManager.Instance.Connection()
 Any tips on what I'm missing? I'm writing in the iLogic environment of Inventor.
bradeneuropeArthur
https://forums.autodesk.com/t5/inventor-customization/use-inventor-vault-add-in-through-inventor-api...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
I thought that you needed the vault properties from inventor.
Mistake.
What version of inventor and vault are you using, because they need a different approach regarding the connection.
put this is your code and the rest will explained by press enter after this code snap.
Implements IExplorerExtension
you get some events where the connection is provide automatically.
 Public Function CustomEntityHandlers() As IEnumerable(Of CustomEntityHandler) Implements IExplorerExtension.CustomEntityHandlers
        Return Nothing
    End Function
    Public Function HiddenCommands() As IEnumerable(Of String) Implements IExplorerExtension.HiddenCommands
        Return Nothing
    End Function
    Public Sub OnStartup(application As IApplication) Implements IExplorerExtension.OnStartup
        'Throw New NotImplementedException()
    End Sub
    Public Sub OnShutdown(application As IApplication) Implements IExplorerExtension.OnShutdown
        ''Throw New NotImplementedException()
    End Sub
    Public Sub OnLogOn(application As IApplication) Implements IExplorerExtension.OnLogOn
        oConn = application.Connection
    End Sub
    Public Sub OnLogOff(application As IApplication) Implements IExplorerExtension.OnLogOff
    End Sub
Please let me know if it works for yout.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
