Access to Visuality options at occurrence in DrawingViews
HideoYamada
Advisor Advisor
HideoYamada
Is anyone know how to access visuality options for occurrences in drawing document?
In this few hours, I tried to access to there options via VBA APIs, but could not find the way.
I want to know occurrences is transparent or not, and change the line style of them.
Is there now way?
Freeradical
 Hideo Yamada
https://www.freeradical.jp
xiaodong_liang
Autodesk Support
Autodesk Support
With my experience, you might have to select the browser node by API, and call the corresponding control definition, e.g. the other post talks:
https://forums.autodesk.com/t5/inventor-customization/apply-hidden-line-in-a-component-by-api/td-p/7...
and this article below shows how to get all commands:
http://spiderinnet2.typepad.com/blog/2012/07/inventor-net-find-all-the-control-definitions-1.html
I am investigating if there is any other API ways to triggle the two options.
HideoYamada
Hello xiaodong,
Thank you for your response.
The way using command manager is not enough to do what I want.
I want and wait for new APIs to be available.
Freeradical
 Hideo Yamada
