Access Derived part's Base Component's iProperties
Nejc.Leban
Nejc.Leban
Hi everyone.
I'm looking for a way to access the iProperties of the Base component of a Derived part and copy them to the Derived part. I've looked through the forum, but I didn't find a way to do it.
Nejc
bradeneuropeArthur
Public Sub main
	Dim A As Inventor.PartDocument = ThisDoc.Document
	Dim b As Inventor.Document = A.ReferencedDocuments.Item(1)
	CopyModelPropertiesToDerivedPart (ThisApplication,A,b)
	End Sub
    Public Sub CopyModelPropertiesToDerivedPart(oInvApp As Inventor.Application, oDoc As Inventor.Document, oInvRefDoc As Inventor.Document)
        Dim prop As Inventor.Property
        Dim propset As Inventor.PropertySet
        Dim RoutineInheritProperties As Inventor.Property
        Dim DimensionDirty As Boolean = False
        For Each propset In oInvRefDoc.PropertySets
            For Each prop In propset
                Try
						oDoc.PropertySets.Item(propset.DisplayName).Add(prop.Expression,prop.DisplayName)
                Catch ex As Exception
                    Try
						oDoc.PropertySets.Item(propset.DisplayName).Item(prop.DisplayName).Expression = prop.Expression
                    Catch ex2 As Exception
                    End Try
                End Try
            Next
        Next
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Nejc.Leban
Man, that's awesome. 🙂
Thanks.
Jarno_marasBL4DC
I keep getting an error when I run this rule. I read that it has something to do with the office version on my computer. Do you know the fix to this issue? My coding skills are near-to non-existing.
Error code:
"System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)"
Thank you in advance!
Jarno_marasBL4DC
Error code:
at ThisRule.Main()
