Ilogic Elbow multi value
SpokenEarth
Message 1 of 8
SpokenEarth
Hi community members, In a new to Ilogic, I'm trying to create a variable elbow with multi values.
Example:
DN10: wall thickness multi value, Radius multi value
DN20 wall thickness multi value, Radius multi value
DN25 wall thickness multi value, Radius multi value
I hope someone can I assist me
Replies (7)
Message 2 of 8
CGBenner
@SpokenEarth
Hi,  I'm wondering if you could accomplish what you need with an ipart, or a Content Center family table.  Will you be using this for tube & pipe?
Chris Benner
Message 3 of 8
SpokenEarth
Good point, i used Iparts before and sometimes can trigger conflict.
My intention is not to use it in tube & pipe module
Message 4 of 8
CGBenner
@SpokenEarth
Thank you for clarifying that.  I'm going to move this to the Customization forum, you'll find a lot more help with ilogic in that group.  Good luck!
Chris Benner
Message 5 of 8
J-Camper
Here is a quick little rule that should trigger when ever the Text Parameter "DIN2605" is changed:
'Triggers rule to run when parameter is changed:
Dim curOption As String = DIN2605
'Current List: ("DN10", "DN20", "DN25", "DN32")
If curOption = "DN10"
	Parameter("EXTERNAL_Ø") = 21.3 mm
	Parameter("R") = 28 mm
	Parameter("WALL_THICKNESS") = 2 mm
Else If curOption = "DN20"
	Parameter("EXTERNAL_Ø") = 23.3 mm
	Parameter("R") = 30 mm
	Parameter("WALL_THICKNESS") = 3 mm
Else If curOption = "DN25"
	Parameter("EXTERNAL_Ø") = 26.3 mm
	Parameter("R") = 32 mm
	Parameter("WALL_THICKNESS") = 4 mm
Else If curOption = "DN32"
	Parameter("EXTERNAL_Ø") = 27.3 mm
	Parameter("R") = 34 mm
	Parameter("WALL_THICKNESS") = 5 mm
'Update Document
InventorVb.DocumentUpdate()
I filled in random values for the different configurations, so those are likely incorrect.  It should be pretty straight forward to see how you can change those preset values, but let me know if you have any questions
Message 6 of 8
SpokenEarth
Hi JCamper, thank you for helping me out, the code works fine. What if I need to have different values for all DN?
Example:
DN10 wall thickness 2, 4, 6 ,8
DN20 wall thickness 5, 6, 7 ,10
DN25 wall thickness 8, 10, 12 ,14
Message 7 of 8
J-Camper
You can set a MultiValue list after setting the "WALL_THICKNESS" Parameter to a value on that list:
	Parameter("WALL_THICKNESS") = 2 mm ' temporary value set to lowest in list
	'Set List Options:
	MultiValue.SetList("WALL_THICKNESS", 2 mm, 4 mm, 6 mm, 8 mm)
	Parameter("WALL_THICKNESS") = 5 mm ' temporary value set to lowest in list
	'Set List Options:
	MultiValue.SetList("WALL_THICKNESS", 5 mm, 6 mm, 7 mm, 10 mm)
	Parameter("WALL_THICKNESS") = 8 mm ' temporary value set to lowest in list
	'Set List Options:
	MultiValue.SetList("WALL_THICKNESS", 8 mm, 10 mm, 12 mm, 14 mm)
	'Set List Options:
	MultiValue.SetList("WALL_THICKNESS", 5 mm) 'Not sure what these could be
'Update Document
This should still only trigger if the "DIN2605" Parameter gets changed, or if you use run all rules.  So it could overwrite your selection if you change the list value and then run the rule.
So here is a more complex rule that should avoid overwriting, unless the current value is not a part of the new list:
Sub Main
	Dim WallThicknesses As New List(Of String)
		WallThicknesses.AddRange({"2 mm", "4 mm", "6 mm", "8 mm"})
		'Check current against list:
		If NotIncluded(Parameter.Param("WALL_THICKNESS").Expression, WallThicknesses) Then Parameter("WALL_THICKNESS") = WallThicknesses.Item(0)
		'Set List Options:
		MultiValue.List("WALL_THICKNESS") = WallThicknesses
		WallThicknesses.AddRange({"5 mm", "6 mm", "7 mm", "10 mm"})
		'Set List Options:
		WallThicknesses.AddRange({"8 mm", "10 mm", "12 mm", "14 mm"})
		'Set List Options:
		WallThicknesses.AddRange({"5 mm"})
		'Set List Options:
	'Update Document
End Sub
Function NotIncluded(testString As String, sampleList As List(Of String)) As Boolean
	Dim Result As Boolean = True 'Default Response
	'Check list for match
	For Each s As String In sampleList
		If testString = s Then Result = False : Return Result 'Return match found
	Next
	'Return no match found
	Return Result
End Function
Let me know if you have any questions, or if this is not working as intended
Message 8 of 8
SpokenEarth
Thank you so much!!!....it worked perfect
