iLogic to Batch Export PDF and DXF
esaldana
Message 1 of 13
esaldana
Good morning everyone,
I found this great code (shown below) at: AutoDesk Inventor - Batch Exporting PDFs & DXFs with iLogic - Thingimajigs,
done by Lance: Lance Skelly | GrabCAD
Is really good, and saving me a lot of time when exporting,
the question I have is if there is a way to export only the profile of my parts when exporting to DXF's and not the whole title block and dimensions? any suggestions are welcome.
Thanks you,
code:
Sub Main()
  Dim myDate As String = Now().ToString("yyyy-MM-dd HHmmss")
  myDate = myDate.Replace(":","")  ' & " - " & TypeString
 userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope")
 UserSelectedActionList = New String(){"DXF & PDF", "PDF Only", "DXF Only"}
  UserSelectedAction = InputListBox("What action must be performed with selected views?", _
          UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options")
      Select UserSelectedAction
   Case "DXF & PDF": UserSelectedAction = 3
   Case "PDF Only": UserSelectedAction = 1
   Case "DXF Only":    UserSelectedAction = 2
   End Select
 If userChoice Then
   Call MakePDFFromDoc(ThisApplication.ActiveDocument, myDate, UserSelectedAction)
  Else
   For Each oDoc In ThisApplication.Documents
    If oDoc.DocumentType = kDrawingDocumentObject
     Try
      If Len(oDoc.File.FullFileName)>0 Then
       Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction)
     Catch
     End Try
   Next
 End Sub
 Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer)
 ' oPath = oDocument.Path
 ' oFileName = oDocument.FileName(False) 'without extension
  'oDocument = ThisApplication.ActiveDocument
  oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
  ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
  oContext = ThisApplication.TransientObjects.CreateTranslationContext
  oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
  oOptions = ThisApplication.TransientObjects.CreateNameValueMap
  oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
 oFullFileName = oDocument.File.FullFileName
  oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1)
  oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\"))
  oFilePart = Left(oFileName, InStrRev(oFileName, ".")-1)
 'oRevNum = oDocument.iProperties.Value("Project", "Revision Number")
 ' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
  oOptions.Value("All_Color_AS_Black") = 0
  oOptions.Value("Remove_Line_Weights") = 0
  oOptions.Value("Vector_Resolution") = 400
  oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
  'oOptions.Value("Custom_Begin_Sheet") = 2
  'oOptions.Value("Custom_End_Sheet") = 4
 ' End If
 'get PDF target folder path
  'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
  oFolder = oPath & "\iLogic PDF's (" & DateString & ")"
 'Check for the PDF folder and create it if it does not exist
  If Not System.IO.Directory.Exists(oFolder) Then
   System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
  oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf"
 'Publish document
  If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then
   oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's
  If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then
   oDocument.SaveAs(oFolder & "\" & oFilePart & ".dxf", True) 'For DXF's
  'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".dxf"), True) 'For DXF's
  '------end of iLogic-------
 End Sub
Replies (12)
Message 2 of 13
Curtis_Waguespack
Hi @esaldana
You can turn off the layers of the objects you don't want to include and then do the export, then turn the layers back on.
Here is a PDF export example that demonstrates this.
I hope this helps.
Curtis
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
'add layers to collection
Dim oCollection As ObjectCollection
oCollection = ThisApplication.TransientObjects.CreateObjectCollection
oLayers = ThisApplication.ActiveDocument.StylesManager.Layers
oCollection.Add(oLayers(("Title (ANSI)")))
oCollection.Add(oLayers(("Border (ANSI)")))
oCollection.Add(oLayers(("Dimension (ANSI)")))
'turn layers off
For Each oLayer In oCollection
	oLayer.visible = False
Next
ThisApplication.ActiveView.Update()
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
oPDFAddIn.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oDataMedium)'For PDF's
MessageBox.Show("PDF saved to: " & oFolder, "iLogic")
Process.Start(oFolder)
'turn layers back on
	oLayer.visible = True
Next
Message 3 of 13
esaldana
Thank you Curtis,
I applied the section of the layers on/off to the existing code and it works really well,
Not to be too demanding this morning, but is there any way to instead of cancelling the layers that I don't want, just export to dxf the flatten portion , I'm using exclusively sheet metal and all that I always need is the flat pattern to be either lasered or punched. Usually I used the export from the actual sheet metal part but that way I have to go one by one, while this code is batching from the drawings which is nice.
thanks for you help,
Eric
Message 4 of 13
Curtis_Waguespack
Hi @esaldana ,
So you want to run the rule from the assembly file and export DXFs for all sheet metal part flat patterns?
Or you want to run the rule from a drawing file of the assembly and export DXFs for all sheet metal part flat patterns?
Or you want to run the rule from drawing file that contains views of multiple flat patterns and export DXFs for all sheet metal part flat patterns?
Message 5 of 13
esaldana
Hi @Curtis_Waguespack ,
really appreciate your attention to this message,
Wherever is the easiest, I will always have a single file (DWG) with several sheets (assembly drawing firs, then the sub-assemblies and finally all the parts) and need to create a single PDF with all those sheets included, finally I need to create DXFs' for all the parts having a flat pattern on them.
What do you suggest me?  It could be from either the top assembly or top drawing.
Honestly what I liked it from that original code was being able to select from either export only PDF or DXF or both and also the creation of folder with time stamp, so I could know my latest output.
But it can be different as soon it accomplish the tasks.
Thank you,
Eric
Message 6 of 13
Curtis_Waguespack
Hi @esaldana
I would run this from the top level drawing, but you can run it from the top level assembly...
if you run it from the assembly, you get a PDF of the assembly, which I'm not sure sure is useful...
This runs through all the referenced files and DXFs out the sheet metal flat patterns... if there is no flat pattern it will create it, so you might see the model open and close in that case.
I just set it to output to a temp folder, but you can set the folder as needed... there are a few examples commented out for this also.
Post back if it's not exactly what you're after, it can likely be tweaked to be what you're after.
I hope this helps.
Curtis
Sub Main()
  	Dim myDate As String = Now().ToString("yyyy-MM-dd HH:mm:ss")
	myDate = myDate.Replace(":", ".")
	'change this as needed
	oRoot = "C:\Temp\"
'	oRoot = ThisDoc.Path 'use the document's containing folder path
	oSuffix = "Outputs"
	'oSuffix = iProperties.Value("Project", "Project") 'use the document's Project#
	'oSuffix = iProperties.Value("Project", "Part Number") 'use the document's Part#
	'get target folder path
	oFolder = oRoot & "\" & oSuffix & " (" & myDate & ")"
	'open the folder
	Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	'PDF of the file you're running it this from
	Call PDF_Out(oDoc, oFolder)
	'Loop through all referenced documents
	j= 1
	For Each oDoc In ThisApplication.ActiveDocument.AllReferencedDocuments
		oName = oDoc.DisplayName
		ck = j Mod 2
		If ck = 0 Then
			oFlicker = ".......... "
		Else
			oFlicker = ".... "
		ThisApplication.StatusBarText = "Processing DXF" & oFlicker & oName
		j = j + 1
		'created DXF's of sheetmetal parts
		Call DXF_Out(oDoc, oFolder)
	Next
	ThisApplication.StatusBarText = "Done!!!!!"
End Sub
 Sub DXF_Out(ByRef oDoc As Document, oFolder As String)
	oFullFileName = oDoc.FullFileName
	oFileName = Right(oFullFileName, Len(oFullFileName) - InStrRev(oFullFileName, "\"))
	oName = Left(oFileName, InStrRev(oFileName, ".") - 1) 'name without extension
	'look at only Sheet metal parts
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Dim oCompDef As SheetMetalComponentDefinition
		oCompDef = oDoc.ComponentDefinition
		i = 0
		For Each oBody In oCompDef.SurfaceBodies
			If oBody.IsSolid = True Then
				i = i +1
		Next
		If i > 1 Then
		 	Exit Sub
		'check for flat pattern
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
			oCreated_Flat = True
		Else 'if flat pattern exists
			oCompDef.FlatPattern.Edit
		sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=IV_INTERIOR_PROFILES"
		sFullDXFname = oFolder & "\" & oName & ".dxf"
		'Output the DXF
		oCompDef.DataIO.WriteDataToFile(sOut, sFullDXFname)
		oCompDef.FlatPattern.ExitEdit
		Try
		If oCreated_Flat = True Then oDoc.Save
		Catch
		End Try
		oDoc.Close
 End Sub
Sub PDF_Out(ByRef oDocument As Document, oFolder As String)
	ThisApplication.StatusBarText = "Processing PDF.........." & oDocument.displayname
	oFullFileName = oDocument.FullFilename
	oName = Left(oFileName, InStrRev(oFileName, ".") -1) 'name without extension
	sFullPDFname = oFolder & "\" & oName & ".pdf"
	oDataMedium.FileName = sFullPDFname
	'output the PDF
End Sub
Message 7 of 13
esaldana
The PDF goes really well and fast,
but is the only file in that temp folder,
I have the following error message:
I have absolutely no idea of the error meaning,
Do you see something there?
Thank you Curtis,
Message 8 of 13
Curtis_Waguespack
Hi @esaldana
I just ran this on one of Autodesk's sample assemblies and the DXF part hit an error with that assembly in trying to access the sheet metal part files... so I added a missing line to open the files... it was probably accessing files in Inventor's memory when I ran this earlier.... so the error didn't happen...
Give this a try and see if that resolved it.
If not, What version of Inventor are you using?.... and can you provide a simple file set that demonstrates the problem, to test?
I hope this helps.
Curtis
Sub Main()
	oRoot = "C:\Temp"
	'oRoot = ThisDoc.Path 'use the document's containing folder path
	oSuffix = "Outputs"
	'open the folder
	j= 1
		ck = j Mod 2
		If ck = 0 Then
		Else
			oFlicker = ".... "
		j = j + 1
	Next
End Sub
	oCreated_Flat = False
	Logger.Info("oName: " & oName)
		Logger.Info("Is Sheetmetal")
		i = 0
				i = i +1
		Next
		If i > 1 Then
		 	Exit Sub
			Logger.Info("HasFlatPattern: " & HasFlatPattern)
			oCompDef.Unfold
			Logger.Info("Trying to get flatpattern...")
			ThisApplication.Documents.Open(oFullFileName, True)
		Logger.Info("sFullDXFname: " & sFullDXFname)
		'Output the DXF
		Try
		Catch
		End Try
		oDoc.Close
 End Sub
	'output the PDF
End Sub
Message 9 of 13
esaldana
so close.
This time one of the DXF's was created (the 3rd one in the drawing, see attached PDF),  but not the others, got an error message after creating the first DXF.
I'm using Inventor 2020
Thank you Curtis,
Message 10 of 13
Curtis_Waguespack
Hi @esaldana
Note sure what the issue is, but I added some debugging and error catching to this version, so maybe you can figure out what it's tripping on...
Go to the View tab , User Interface button/pulldown, and check the iLogic Log option, they you can watch the log and see if you can tell what the issue is with the part file.
If not, I'd need to have the files to test, if you can share them, you can zip them and attach them here.
I hope this helps.
Curtis
Sub Main()
	oRoot = "C:\Temp"
	oSuffix = "Outputs"
	'open the folder
	j= 1
		ck = j Mod 2
		If ck = 0 Then
		Else
			oFlicker = ".... "
		j = j + 1
	Next
End Sub
		Logger.Info("File Name: " & oFileName)
		i = 0
		Logger.Info("Looking at solid bodies....")
				i = i +1
		Next
		If i > 1 Then
		 	Exit Sub
		Logger.Info(".....solid bodies ok")
			Logger.Info("HasFlatPattern: " & oCompDef.HasFlatPattern)
			Logger.Info("/////////////\\\\\\\\\\\\ Trying to create flatpattern...")
			Try
				oCompDef.Unfold
			Catch ex As Exception
				Logger.Info("Problem creating flat!!!!")
				Logger.Info(ex.Message)
			End Try
			Try
				Logger.Info("Problem editing flat!!!!")
			End Try
		'Output the DXF
		Try
			Logger.Info("DXF created!!!:  " & sFullDXFname)
			Logger.Info("Problem creating DXF!!!!")
		End Try
		Try
			Logger.Info("Saving the file.")
		End Try
		oDoc.Close
		Logger.Info("*******************")
 End Sub
	'output the PDF
End Sub
Message 11 of 13
ErnestoGL
Thank you for this rule, it´s really amazing. I´ve been trying to modify the rule in order to get the "Title" ipropertie from the part file as a PDF file name and adding the revision number at the end but I´ve not get it. Im realatively new in iLogic and programming, doy you have any ideas guys?
Message 12 of 13
ryan_holtonVREQV
Community Visitor
Community Visitor
Would you be able to alter this code so that I can pick the save destination / file path each time rather than it automatically saving to a specified location.
Message 13 of 13
ALadZ339U
Observer
Observer
can i pleaswe get the code to save the pdf and dxf file in same folder where the original drawing file is ?
