Why the errors T2002 and T2003 appears during an analysis?
smirnov.da
smirnov.da
Hello!
Why the errors T2002 and T2003 appears during an analysis when I set the orientation of shell elemets? Without specifying orientation, the analysis is complited.
John_Holtz
Autodesk Support
Autodesk Support
Hi @smirnov.da
Your issue looks like this problem on knowledge.autodesk.com. See T2002 and T2003 errors during a Nastran analysis.
Instead of editing the Nastran file as suggested in the article, you could try rotating the material axis by 90 degrees. (Then switch the X and Y material properties, or 1 and 2 material properties.) Let us know if that works and I will add the suggestion to the article.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
smirnov.da
Hello!
I rotated the orientation axis of the material 90 degrees and rotated the coordinate system for this shell panel.
During the analysis,  received a E5000 error, I fought it and killed it😅. I got strange results for this panel which are shown below...
