Static loads more than frequency response
MACH.No
MACH.No
Hi All,
i m trying to do a vibrational analyis on a structure which is excited by a vibrating force of 80KN at 50Hz. To check the stresses level and compare them with the related standard allowables and fatigue allowables I tried to get stress results out of frquency response. But when I compare the results with the static stresses itself ( having 80kn load in static enviroment) the values in static condition is higher. What can be the reasons?
thanks
John_Holtz
Autodesk Support
Autodesk Support
Hi @MACH.No
It could be that your model has mass and inertia, and therefore the displacement (and stress) in a dynamic situation is smaller than in a static situation.
Here is a generic plot showing the transmissibility ratio for a frequency response analysis. When the forcing frequency is larger than the natural frequency, the displacements are smaller.
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
