- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello. I’m writing from Japan.
I’m a beginner at English, so I’m sorry for my poor English..
This time, I tried to perform the thermal stress analysis of a three-layer cantilever.
There is a temperature difference between the first layer and the third layer.
When I analyzed it, a model was displaced in a horizontal direction.
Intuitively, the model is displaced in vertical direction because of the temperature difference between the first layer and the third layer. (Like below figure)
I think this result was not correct.
I just started simulation at Nastran In-CAD and using Inventor, so I want you to give some advice.
I’ll describe below what procedure I analyzed.
I used a “Mate constraints” with each part at "Inventor 2019", then I used a “Mate constraints” with YZ plane of the first layer and YZ plane of the second layer. I dittoed with YZ plane of the third layer and YZ plane of the second layer.
Lower figure is image of three plates before constraints.
At Nastran In-CAD, I analyzed as below like “Heat Transfer and Thermal Stress Analysis of an Exhaust Manifold” in tutorials.
Firstly, I chose the “linear steady state heat transfer and thermal stress”
Due to face constraints between the first layer and the second layer, and the third layer and second layer, I did “surface contacts" automatically. Then “Contact type” was bonded and “Penetration type” was symmetric.
A material of the first and third layer was “Aluminum 6061”, and a material of second layer was unique orthotropic material which was referred to “Aluminum 6061”
“Reference temperature” of the first layer was 353.15K, and “Reference temperature” of the third layer was 273.15K. I didn’t input the second layer’s “Reference temperature”.
All parts were solid elements.
The mesh element size was 0.01 and I selected “Liner” from “Element order”.
The load type was “temperature”, the first layer is 353.15K, and the third layer is 273.15K.
I had analyzed this, then I performed thermal stress analysis based on result of “Heat Transfer and Thermal Stress Analysis of an Exhaust Manifold”.
I did two below commands like tutorials.
- In the tree view, right-click on Manifold Analysis, and choose Duplicate. This will create a copy of the analysis with the name as Manifold Analysis - Copy.
- Now, Manifold Analysis - Copytree is in active mode. Under Subcases left-click on Subcase 1 to select the name, and rename it to Subcase 2. Remove the Initial Temperature load from Subcase 2 as it is not required for a thermal stress analysis.
The load type was “From Output”, and I selected FNO file(result of “Heat Transfer and Thermal Stress Analysis of an Exhaust Manifold”) at “Result File” in the “Load Definition section”
The right end face was constraint because this model is a cantilever.
I analyzed these conditions.
Thank you very much for reading the message through to the end.
Please some advice and helps for my thermal stress analysis.
Kind regards,
Takaya Nakamura(7515085)
